Old 10-28-2006, 08:52 PM   #1
cookeville34's Avatar
Auburntown , Tennessee
Send a message via Yahoo to cookeville34
Wiring notes from the confused
Some observations I made today:
1) When I brought the trailer home, the front outlets stopped working except for the sink outlet. I discovered the fridge outlet had french fried inside the wall, easy enough fix, but two rear outlets above bunks and bath oulet still do not work.
2) Interestingly there was a secon 110V wire in the fridge outlet that apparently had never been wired to anything, I temp hot wired it and could find no use for it, so I capped it back off.
3) There was a 110V wire plugged into the fridge outlet that appears to connect to the Univiolt on the opposite side of the trailer, is this correct?
4) The two outlets above the middle bunks and bath outlet do not work, even when a hot wire is temp plugged into them. Although if I temp hot wire these same three outlets the Univolt hums like a sewing machine, even if its not plugged up to the fridge outlet.
5) My trailer has a place for just one battery, all the 12 volt lights work and the battery gauge on the inside works most of the time. I did not hook the Univolt wires up to the battery, should I?
6) There is a 12v light switch by the door, what does it do? There is a 12v light switch by the couch that turns on a little round light outside.
1979 Airstream Sovereign International, 31'. VIN# I31T9J0162
1992 Buick Roadmaster Wagon, 5.7L - V8, stock 5000# tow rating, posi, aux trans cooler, rear coil over shocks, 2" rear spring lift kit, flowmaster exhaust.
cookeville34 is offline   Reply With Quote
Old 10-28-2006, 09:33 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by cookeville34
2) Interestingly there was a second 110V wire in the fridge outlet that apparently had never been wired to anything, I temp hot wired it and could find no use for it, so I capped it back off.
Do you have an air conditioner on your coach? If not, it could be the lead for it
That doesn't sound right. Your 120 volt lead for your Univolt should be fairly short, maybe a foot or two long. Possibly a PO modification?
Sounds like for some reason those outlets are hooked up to the 12 volt system , check for 12 volts at those plugs before continuing.
If the Univolt is not connected to the battery, it will not be able to charge it, and eventually the battery will go dead.
You should have a small light over your entry door, this switch should control that light, if it is the switch I am thinking of.
1975 P30 wiring diagram (as promised) ... Hayseed Airstream Motorhome Forums 1 11-22-2012 02:28 PM
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
