Old 08-07-2013, 08:48 PM   #1
2008 23' International CCD
Denver , Colorado
Wiring new things
What's a recommended method for wiring up a new 12v fan for the Air Head composting toilet I'm installing in 23' 2008 CCD International? I removed the old toilet and box it sat on to reveal the black tank. It is staying. The Air Head will vent to the old black tank vent pipe. New box will let the Air Head sit lower to the floor. Now I'm looking for some wires to connect the Air Head's 12v muffin fan.
I see two wires (violet and white) escaping down under the black tank heading to the rear of the trailer somewhere. Can I splice into one of those two wires for my hot connection and keep looking for a ground (assume it will be a black wire)? Or do I need to run new wires back to the DC panel (beneath my refrigerator, I think, with the little black twisty lock to keep the door shut)?
Thanks for the tips.
Jim and Marsha
"Tow'd Hall"
AIR #35886
JimmyT is offline   Reply With Quote
Old 08-07-2013, 09:25 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Unless you know what switch and what fuse controls those wires you see, it's probably best to run all new wiring back to the DC fuse panel.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-10-2013, 11:04 AM   #3
Denver , Colorado
Good points, Bubbagumper and Protagonist. Thanks. I'll keep poking around - but (thinking out loud) if those two wires do run the exhaust fan and that fan is controlled by the button on the fan, then I might be able to tap into those? They'd be hot to the exhaust fan right? I'm trying to find a wiring diagram for the trailer.
Jim and Marsha
"Tow'd Hall"
AIR #35886
Old 08-10-2013, 06:58 PM   #4
Denver , Colorado
Yes, bubbagumper, I do. Assume violet will read +12v and ground will read 0 volts? I also checked the circuit box: the violet runs the sewer something (perhaps the gauge?) as well as bedroom and closet lights. I'm tempted to tap into that - this little fan pulls .06 amps. Yes. dot zero six. So I don't expect it will overload the 20 amp circuit especially as I'm changing lights gradually to LED.
Jim and Marsha
"Tow'd Hall"
AIR #35886
