Originally Posted by nevisstudio
hello all..
our trailer is finally gutted and now looking at wiring it up..wow overwealming
so ill start with the simple questions-
has anyone come across a wiring diagram for a safari...
has anyone used low voltage(dc current) lighting..
wiring for a genrator...
any insight would b very appreciative..
thanks
rich
Hopefully I will be rewiring ours in the next couple weeks. I think your is old enough it's like ours and there is both 110v fixtures and 12v fixtures. In a couple places I will retain this set up. What I am doing away with is our coach had several 120v-12v step down transformers and a City/battery switch. I am going with a central 12v transformer in the form of a Intelipower to handle both battery charging and 12v systems.
I plan to draw up some plans and I'll be happy to share once done.
The real problem is WHERE to run the wiring. Airstream ran it ALL through the roof and dropped down to where it was needed. I have been trying to not have to take my inner skin free from the ceiling. I have it off aroudn the floor. I had contiplated drilling the ribs and gromiting but I am concerned about weakening them.
I'm going to see if it will be possible to use the old wires the pull the new Romenx and 12v feeds by pulling the trim around the vents and over head light and drilling just enough rivets to pull the inner pannel down 3-4 inches so I can reach in and guide things and keep the insulation from balling up.. I think it can be done. Let you know when I try.
