Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-23-2006, 09:21 AM   #1
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Wiring help with 1958 Traveler
I need to replace at least some of the wiring to the 7 pin plug. The wires are brittle and I do not want to take any chances with it.
Does someone know an easy way to access the wiring to the parking/brake lights? I am hoping to be able to snake new wires to the axles later. My 1st thought is to put a hole in the plywood floor near where the wire harness comes into the belly pan. I picked up a plastic Deck Plate cover yesterday and then I can simply intall this cover to allow future access to this area.
Any help from someone with experience with this vintage Los Angeles built trailer would be very helpful.
Steve
prairieschooner is offline   Reply With Quote
Old 09-23-2006, 11:46 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Steve
Steve,
I think that your plan is a good one. You might find that the wires inside the trailer's confines are a-ok. The harness outside the trailer gets brittle.
Consider a second vehicle end plug near the belly skin, with a removeable umbilical cord that has 2 plug ends, like Airstream did on the 70's trailers.
Then you can remove the cord and store it out of harm's way.
Wiring to the brakes can be run inside the belly skin, with a grommet where the wire exits and goes to the brakes.
Good Luck with your wiring project.
Uwe
www.area63productions.com
Old 09-23-2006, 03:26 PM   #3
1958 18' "Footer"
Thanks for the input. I will be trying to keep the exterior as close to original as possible. If my plan with the plastic Deck Plates works, it should be easy to repair/replace the wire cable in the future. I have two plastic Deck Plates but I am hoping to use the smaller of the two (just my hands are large). I will post pictures after I get that project started. I will complete the repair and sealing of the plywood floor with West Systems Epoxy before I start the wiring.
Steve
Steve
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 13 04-07-2021 02:20 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
