Old 05-12-2016, 09:22 PM   #15
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
Thank you.
TheCabin is offline   Reply With Quote
Old 05-15-2016, 07:09 PM   #16
2006 28' International CCD
Germantown , Tennessee
Thanks everyone for all the input. I read the manual two (or three) times yesterday. And today I've been working on it all day and have everything in good order, almost. The only thing I can't figure out is how to get my ME-BMK to talk to my ME-ARC50 remote. The sense module keeps flashing red.
The troubleshooting guide says that this means my telephone cable isn't connected correctly. But I've gone through multiple times connecting and reconnecting with no luck. I'm using the cables sent with the unit. Tomorrow I'm going to buy a new cord and see if that makes any difference. If it doesn't then I'm not sure what the problem is.
Now I've just got to mount the solar panels and connect them to the solar controller and the wires I've ran to the batteries.
jami20 is offline   Reply With Quote
Old 05-15-2016, 07:18 PM   #17
Hmm, I just tried two other telephone cables I had in the house. The light is still blinking red.
Old 05-15-2016, 08:00 PM   #18
lewster's Avatar
Naples, FL , Hood River, OR
You can't use a standard phone cable as Magnum uses 4 conductor 'data' cables that 'look' like phone cables but have one end reversed.
When you line up the 2 RJ-11 plugs facing each other with the little disconnect clips oriented the same way, the wire colors should line up.
Also make sure that you have the ME-BMK plugged into the correct port of the inverter's plug stack. Double check your wiring of the shunt twisted pair to be certain that they are polarity correct (you have to use the entire length of the orange/blue twisted cable as supplied), as you should do at the BMK's black interconnect box.
If you still have issues, get with Magnum tech support to troubleshoot your installation.
Old 05-15-2016, 08:33 PM   #19
Thanks Lew. I was not aware of the cables, that good to know. I'll double check my wiring tomorrow and plan on calling Magnum if needed.
Old 05-16-2016, 08:07 AM   #20
Zil
egg harbor city , South Jersey
Telly wires are RJ-11 and have 4 wire contacts. These data cables are RJ-12 and have six contacts. I have a hard time finding them even on-line.
Zil is offline   Reply With Quote
Old 05-16-2016, 08:11 AM   #21
Zil
I guess it all depends on the amp-rating of the buss bar and the awg of the cables. I had to bring the DC through a buss bar and it works just fine, with very little voltage drop.
Old 05-16-2016, 08:20 AM   #22
lewster's Avatar
Magnum uses 4 conductor communication cables in 2 orientations: 2 twisted pairs from inverter to remote and the BMK and 4 flat wires for the battery temp. sensor.
They NEVER use 6 conductor cables.
Lew Farber
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 05-16-2016, 08:44 AM   #23
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
Originally Posted by lewster View Post
Not a disconnect pre se, but a manual re-set marine circuit breaker like this:https://www.bluesea.com/products/cat...=Surface_Mount.
They should be sized according the the cable going from the batteries to the bis bar. This adds the required circuit protection and gives you the switching option as well.
Lew, I put a rated fuse near the battery for the inverter positive feed. Then a rated cut off switch just after that. Is this overkill? I am afraid that anyone turning off AC power would think that power is off. It is still possible for the inverter to take over producing AC that could shock someone. I guess it is belt and suspenders.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 05-16-2016, 08:08 PM   #24
lewster's Avatar
Nope! I do that on a regular basis. You should be good to go!
Lew Farber
541-490-6357
Upgrading from Tripplite to Magnum inverter/charger russ240 Sprinter and B-van Forum 12 04-27-2018 10:54 PM
Replace House Batteries (Magnum Inverter) MILATV Sprinter and B-van Forum 24 11-04-2014 06:11 PM
prices of Magnum MS2812 2800W Inverter with 125 Amp Charger carl2591 Batteries, Univolts, Converters & Inverters 42 01-28-2014 03:26 AM
Magnum Inverter upgrades Support Admin Airstream Classifieds 0 09-23-2013 12:28 PM
Magnum Energy inverter - chargers Jammer Batteries, Univolts, Converters & Inverters 5 03-22-2011 10:11 PM
