Old 06-21-2009, 08:12 PM   #1
Johnsonbrg , Pennsylvania
Wiring Diagram...HELP!!
I'm trying to get my 1966 Overlander brakes working and am in dire need of a wiring diagram asap. I have power for the blue wire when I apply the brake controller at the: umbilical, underside belly access door, and at the rear of the coach at the fuse panel(?). Where does the cirucuit go from the access panel curbside front? If anyone has a dieagram, or can tell me where to get one will be at the TOP of my xmas card list! Thanks in advance.
randylindberg@hotmail.com
rlindberg is offline   Reply With Quote
Old 06-21-2009, 08:18 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Randy!
I believe that the blue wire in your Airstream is the charge line while the Yellow line is your brake wire. See the pdf attached to this post for the wire colors and patterns utilized by Airstream for the umbilical cord in 1966.
Kevin
Kevin D. Allen
AIR #827
Old 06-21-2009, 08:31 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
7 way in color
hope this helps
Old 06-22-2009, 05:47 AM   #4
Both Help! Anyone know where the brake wire splits to go to each side (left and right)?
Old 06-22-2009, 06:02 AM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you look at the 3rd picture in the first post in this thread:
http://www.airforums.com/forums/f305...tml#post712606
You can see where all the break wires are tied together. This is a different trailer (year) then yours but I suspect it would be similar.
Richard
Old 06-22-2009, 01:46 PM   #6
If I'm looking right, then it is dead center under the floor between the wheel wells. Does thiat mean I have to cut thru my floor, or remove the belly pan? If so, anyone got any fine tuning measurements before I pull out the recip. saw? Has anyone else done this?
Old 06-22-2009, 01:53 PM   #7
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Thats pretty much where it`s at on my Gt,it`s just in front of the axle.I would use a cutting wheel,the alum. is only .025 thick. Dave
easyride is offline   Reply With Quote
wiring diagram banjoman Vintage Kin 2 07-23-2008 05:03 AM
wiring diagram banjoman Electrical - Systems, Generators, Batteries & Solar 1 07-20-2008 10:14 PM
Wiring Diagram please Drifter Electrical - Systems, Generators, Batteries & Solar 1 06-04-2004 06:21 PM
wiring diagram frederic.c01 Electrical - Systems, Generators, Batteries & Solar 1 05-30-2004 01:59 AM
wiring diagram? nu2argosy Electrical - Systems, Generators, Batteries & Solar 2 04-20-2004 07:30 PM
