Old 07-02-2010, 10:08 AM   #1
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Wiring diagram from Umbilical to rear of trailer.
I'm searching for information related to my 1970 Safari. I'm going to be tracking down problems with my electrical system. I have a good idea of what is happening with the 110 power, and the 12v power in front of the univolt.
What I'm looking for is how the system from the umbilical to the marker lights/tail lights and univolt is handled. I believe a harness is run from the front, up into the center ceiling panel, then down.
- I'm "missing" my electric brake breakaway wiring. Where is this typically fed from?
- Where should I be looking for my Brake Line? does this go from the front directly under the bellypan?
I'll be replacing the univolt with an intellipower. Should I just pull all new wires to the back?
Ready for wiring fun this weekend!
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 07-02-2010, 10:38 AM   #2
toastie's Avatar
1955 22' Safari
Great Lake State , .
Hope this helps, this is what I followed..........toastie
toastie is offline   Reply With Quote
Old 07-02-2010, 11:19 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
The breakaway switch is wired into the hot battery charge line right at or near the 7-pin connector, as is the electric hitch jack (if you have one). It then splices into the brake line at or near the same place.
I am not 100% certain of this, but I think the brake wire is the only wire that runs into the belly pan at the 7-Pin connector.
No need to pull new wires unless you have reason to believe that the insulation is bad. All my wiring in three 70s Airstreams that lived their lives in the SW deserts are fine. You'd think in the heat they'd have become brittle and cracked. They are stiff, but not brittle. Airstream used very heavy gauge wire, so no worry about high currents, as long as you tap into the heavy ground (white) and blue (battery charge line).
Zep
Old 07-02-2010, 11:37 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
On our '72 Sovereign, the brake wire (2 conductor 12 gauge wire – blue and white) ran from the connector inside the front skin, inside the wall towards the port side, down through a hole in the front c-channel and plywood, and into the port side frame. It then ran aft along the port side frame until just in front of the first axel. There, using wire nuts, it branched off to the 4 wheels. It dropped down through the belly pan (using rubber grommets) just in front of the axel by each wheel and then ran into the back of the hub. There was maybe 8 inches of the brake wire exposed.
Chris
Old 07-02-2010, 01:00 PM   #5
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Toastie, that document is perfect! Thank you!
So what's the chances my wiring is the correct color? I already know the answer. none.
So my ground (white) is a large (12ga) and I believe I have one more 12ga, maybe black.
I have a ground short somewhere in the trailer. I think I'll just start eliminating possibilities till I find it.
DanB
www.campnova.com
trailer side brake wiring diagram? munimula Brakes & Brake Controllers 9 03-26-2017 10:53 AM
Trailer Umbilical Wiring pfay Lights - Interior & Exterior 6 06-09-2013 01:48 PM
345 KG rear vision wiring diagram moonshine Classic Motorhomes 1 04-15-2010 05:59 AM
New 7-Pin trailer umbilical wiring soldiermedic Electrical - Systems, Generators, Batteries & Solar 3 03-16-2009 12:26 PM
1962 ambassador wiring diagram (umbilical)? Hamb7 Lights - Interior & Exterior 11 03-31-2007 11:59 PM
