Old 07-21-2014, 11:35 AM   #1
1995 31' Land Yacht LE
Jacksonville , Florida
Wiring a second Air Condition
I have a 1995 Land Yacht. I am adding an ac unit over the bedroom. I am going to wire it separately since my coach is only 30 amp. While installing the unit, I found heavy duty 12 ga. wire was already present. There was no power running to this wire even while the coach was plugged in. I would love to use this wire to power my second ac but I don't know where the other end comes out. It does not appear to go to the breaker panel. Is anyone familiar with this?
FLMedic is offline   Reply With Quote
Old 07-21-2014, 11:54 AM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Wiring rear air conditioner off of shore power
I started a thread detailing how i did mine in my 310. I cant remember the exact title of the thread but if you go to my stat page i think youll find it there. Most if not all classic moho are wired so the rear air runs off the generator only. I rewired so it can run off of shore power or the generator.
mayco is offline   Reply With Quote
Old 07-21-2014, 11:59 AM   #3
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
It must come out somewhere - buy yourself a continuity light, clip one end on the wire - than go looking with the other end. Try any extra wires in 110v receptacle boxes, wires in beaker boxes, where your 110v comes into the A/S, etc.
Silver Hawk is offline   Reply With Quote
Old 09-10-2014, 02:16 PM   #4
By the way. I installed the rear a/c and ran an extension cord to the interior just for testing purposes. The Atwxxd (names changed in accordance with forum rules) a/c is extremely quiet and very cold. It was cheaper and as far as I can tell way better than the Dxmetic up front. I still have to hardwire the thing. I was told that the wire i mentioned in a previous post is most likely run by the gen. But with the gen running, I have no power to that line and I can`t find a breaker inside or outside that energizes the wire.
Old 09-10-2014, 02:36 PM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I'm just guessing but that 12 gauge might be a solar pre-wire?
In any event, you've got to find the other end for it to be useful to you!
Bob Martel
WBCCI# 5766
Old 09-10-2014, 03:35 PM   #6
mayco's Avatar
Try to find where the feeds from your generator enter the coach. May be just inside the generator enclosure. Im guessing they terminate in a junction box of some sort. If you find that you may find the other end of that wire.
Old 09-10-2014, 07:25 PM   #7
reinergirl's Avatar
Hollis , New Hampshire
Just FYI
It's perfectly okay per the forum rules to mention vendor names. What's not okay is venting about negative experiences.
Quoted from the CR's;
"This forum is not intended to be a mechanism for people to vent frustrations about vendors or sales from private parties. Please settle your differences with the seller, manufacturer and dealer through the long-established legal or arbitration systems or the Better Business Bureau but not through our community."
reinergirl is offline   Reply With Quote
Second Air ColoCoolAid Member Introductions 0 10-24-2013 02:54 PM
Heat Pump/Air Condition Blowing Hot Air Safari-Rick Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-24-2012 08:30 PM
Second Trailer - Wiring problem jronhunt Electrical - Systems, Generators, Batteries & Solar 2 10-15-2006 11:34 AM
