Old 07-27-2006, 07:17 PM   #15
gparker's Avatar
1970 31' Sovereign
Denham Springs , Louisiana
This voltmeter is the old, cool analog kind with a needle that moves from left to right as voltage goes up. Made by Simpson, about 2 inches across. Bet you could get one on ebay. Of course the new ones are nice-- digital etc and just plug into an outlet like one of those air fresheners.
I guess I will pull some #8 wire through the conduit. Not looking foreward to that.
Greg
gparker is offline   Reply With Quote
Old 07-27-2006, 09:00 PM   #16
Elgin , Texas
Images: 164
Greg
Count your blessings.... I get to pull #6 wire through mine.
bake315 is offline   Reply With Quote
Old 07-27-2006, 10:18 PM   #17
gparker's Avatar
1970 31' Sovereign
The voltmeter I have is an old analog model like you used to see in old movies. Pretty cool. Made by Simpson. Probably find on ebay. Newer ones plug into an outlet like an air freshener.
Old 07-28-2006, 06:37 PM   #18
crowbar68's Avatar
1975 27' Overlander
fort wayne , Indiana
wire pull
don't forget to use "soap" on those wire pulls. it will make it much easier. especially if it's long.
crowbar
crowbar68 is offline   Reply With Quote
Old 07-29-2006, 09:01 AM   #19
Elgin , Texas
Images: 164
crowbar
Yep, I'm acquainted with that lovely yellow slime!
Old 07-29-2006, 10:16 AM   #20
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
pull a small rag through the duct with the soap on it first. it will spread it throughout the entire length. then refish and pull your wire.
liberal amounts make it much easier, we use 5 gallon pails of the stuff for long pulls in 6 inch duct!
john
you call them ferrets, i call them weasels.
Old 09-10-2006, 08:09 PM   #21
bsshrink's Avatar
1969 27' Overlander
Kansas City , Missouri
The problems I had with my 69 Airstream Armstrong AC were impossible to fathom because of inadequate power to the unit. In the shop & on the road it did well, but not at home. Make sure you have at least 10V to the Airstream. 30 amps is preferable with older armstrongs. Next check the freon level. Hope this helps
Jeff
"if only stupid hurt"
Jeff Miller
KCMO
69 Overbudget
03 Silverado 1500HD
bsshrink is offline   Reply With Quote
Old 03-25-2010, 05:55 PM   #22
1989 25' Excella
Lakeside , California
pulling wires
Dave,
How far did you have to pull your wires? I've got a 150 foot run from my breaker box to where I'm planning on putting my 30 amp recepticle. I would love to use #8 instead of #6 to be able to run my a/c without problems. Bob
carpetbob is offline   Reply With Quote
Old 03-25-2010, 08:07 PM   #23
Images: 59
Dave hasn't been here for a couple of weeks. Best send him a PM.
markdoane is online now   Reply With Quote
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
