Old 07-29-2017, 06:20 PM   #1
2005 34' Classic
Moab , Utah
Wiring 2nd AC
I purchased a 2005 34' Classic. I have installed a 2nd Low Profile Dometic AC in the front Vent hole. This is a 30 AMP Airstream. I will have to run a 2nd 110 electrical line to the pedestal. I would prefer to snake the wire through the wall and drill in an exterior box/hookup but I have no idea what is in my way? I do have two windows on the Power Pedestal side, am hoping the gap between them is not rib. Plan to buy a fiberglass fish tape but any input on how to proceed? Thanks... Rob
Can send pics if you can assist? robshort2@att.net
ID:	290801   Click image for larger version
ID:	290803   Click image for larger version
rtshort2 is offline   Reply With Quote
Old 07-29-2017, 09:25 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would remove the trim ring from one of the Windows to see what is in between the 2 windows.
It appears that you can look or feel in the hole next to the AC unit to see if there is a rib.
I would bet there is a horizontal piece between the ribs some where in the wall but you may be able to install the power inlet above that point.
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 08:05 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 07:11 AM
CCD 2nd excursion ChrisAich 2002 - 2005 International 18 07-29-2003 05:34 PM
Financing Travel Trailer as 2nd Home Tax Deduction Mrs Silverback Our Community 8 07-11-2003 07:03 PM
Re: Horn 2nd query Orland Dewey General Motorhome Topics 14 07-11-2003 03:19 PM
