Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-30-2007, 08:48 AM   #1
campadk
campadk's Avatar
Profile:  2007 19' Bambi
Ottawa , Ontario
Wireless Backup Camera for Your Bambi
There have been previous discussions on the forum about the Wireless Rear
Views Camera, and its use on the back of an Airstream. I had concerns on
how well it would work on the back of our Bambi vs on the back of the
vehicle, which is really what this camera was designed for. The concern was mainly
signal strength.
Anyways I decided to take the plunge, and bought the VR3 wireless camera
manufactured by Virtual Reality Video Labs. I bought it at Canadian Tire for
$115.99 Cdn + taxes.
The camera easily mounts on the rear license plate bolts. I used the supplied
wedge shaped mounting shims to tip the camera a bit so it aligns horizontally,
rather than tilted down as the license plate is.
I decided the best way to wire in the camera was simply to connect it in with
the rear hatch light which has a push button switch on it. ie push the button
on and power is supplied to the camera! So when we arrive at the campground
I just send Kate back to turn on the rear light hatch, and voila! the camera is now
on.
Light in the rear hatch just to the right inside the rear hatch...
Red wire from the camera (pos) to other side of the light switch (black wire).
Black wire from the camera (neg) to the white white going to the light...
Camera mounted on license plate with wire into hatch. Note: as per instructions, I didn't cut of
surplus length of camera wire. When needed, I pull out the excess wire from the rear hatch and
looped it up into the rear window. Why?? Well the signal is a tad marginal considering the wireless
signal has to travel from the camera all the way up to the tow vehicle, a bit farther than intended.
By fiddling with the excess wire, I am able to get a bit clearer picture on the monitor. Not sure if
there is any other way to 'boost' the signal.
In my case, I got the clearest picture (of our messy garage) when I sat the camera monitor on
the side of the passengers seat as so. No doubt in actual usage, I might have to fiddle about with
the position to get a clear signal...
I might try mounting the camera up high on the rear of the Airstream which might transmit a
stronger signal to the monitor without having to transmit through the Airstream.... we'll see.
Considering the signal gets a tad marginal, I'd think that use of this camera on an Airstream longer
than a 19ft Bambi would be an issue.
Dave
Camp ADK
Our Bambi - The 40 Winker
campadk is offline   Reply With Quote
Old 04-30-2007, 09:31 AM   #2
SilverRanger
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
Thumbs up
Well done, and very informative! I've been looking at that model, and have seen it on sale locally for under $100.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WBCCI# 4582
WDCU
SilverRanger is offline   Reply With Quote
Old 04-30-2007, 10:22 AM   #3
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
Neat-o. I would like to have a system like that. I've been waiting for someone else to find one that works before I take the plunge
Does it reverse the image from the camera? I've heard that's one thing that's confusing about looking at backup monitors, because we are used to looking at the image in the rear view mirror.
Stephanie
Our family photo blog
Old 04-30-2007, 10:56 AM   #4
RUSSELL
Desert Fox
Profile:  1985 31' Sovereign
Tucson , Arizona
Smile Hi
I wanted to put it on my 31 foot but there was not enough signal. Next unit I will mount on the rear bumper driver side so there is less metall between the receiver and transmitter.
I bought my unit at Costco for 89.95
The first unit I put on my 1952 jeep it sure works like a charm. Great back up mirror.
Regards from Russell in sunny Tucson Az.
RUSSELL is offline   Reply With Quote
Old 04-30-2007, 10:58 AM   #5
campadk
campadk's Avatar
Ottawa , Ontario
There is a button so you can change the orientation. So if the image is upside down (you have the camera flipped) you can flip the image. You can
also flip the image horizontally as well.
I believe there is a simplier version of this camera out there, that doesn't have the 4 buttons. I recommend the 4 button version as you have the brightness and contrast buttons which I need to use to get a clear picture, as well as the image orientation button. The 4th button is on/off.
Dave
Camp ADK
Old 04-30-2007, 11:59 AM   #6
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
I have one also; my approach was a little different. I took a rubber band and hooked it over the emergency window release using the rubber band to attach the camera looking out of the window. I added a 12-volt plug and plugged the unit into the 12 volt socket on the trailer wall, on all the time. I have a backup camera and a rear view camera rolled into one. Worked great on the road, some interference in the city but the antenna is inside of the trailer.
If you had hook the camera into you license plate light all you have to do is turn on your lights to turn on the camera, you don’t have to get out of the car and you can turn on the camera in traffic to see who is behind you. I tow with my lights on anyway. That is what I will do when I set mine up permanently.
BTW I have a 25' trailer.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 05-27-2007, 02:00 PM   #7
campadk
campadk's Avatar
Ottawa , Ontario
Update: Ok so far this camera rates a 2 out of 10... mainly because the signal just is too weak.
Hopefully mounting up just below the rear window will help with the signal... otherwise I'll add this to my list of useless accessories.
Dave
Camp ADK
Old 05-27-2007, 03:15 PM   #8
Alumatube
Alumatube's Avatar
Profile:  Jefferson , Arkansas
Our Wal-Mart had these exact cameras on sale for $50 a couple weeks ago in the electronics department. I passed since we have a 31' 310 RV and it sounds like the distance will be too far.
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
1974 31' Excella (soon-to-be carhauler)
Alumatube is offline   Reply With Quote
Old 07-19-2007, 05:52 AM   #9
campadk
campadk's Avatar
Ottawa , Ontario
Thumbs down Wireless Camera = Useless
The latest on this camera.
One word... S UH KS !
I gave up using it... just too unreliable, picture breaks up, too much static. Tried it on several occassions now to no avail.
What DOES work is something that costs you nothing... something you might already 'own'... they call it 'The Wife' !
The Wife works very well in my opinion, if you add the 2 way radio option.
Anyways Kate and I are getting pretty good using radios to do the whole backup thing... MUCH better then that useless backup camera. I simple have the windows rolled down and have her give constant feedback over the radio during the backup process. I find if she continues to provide feedback, then I can trust that all is well and can focus on manuveuring the trailer.
So maybe I'll just take the camera and mount it on the back of our Yukon instead, and use it for backing up over the ball... so all is not lost.
The wireless signal just isn't strong enough to transmit from the back of the trailer to the front tv console... and thats just a 19ft Bambi. Has got to be worst on anything longer.... so save you're bucks, even though its cheap and you'll be a Happier Camper.
Maybe I should submit my unit to 'Will it Blend'
See Will It Blend? | Presented By Blendtec
Cheers
Dave
Camp ADK
Old 07-19-2007, 06:34 AM   #10
SilverRanger
1968 24' Tradewind
Milton , Delaware
Thanks for the report, Dave. Glad I didn't take the plunge this time.
2005 Bambi
1968 Trade Wind
WBCCI# 4582
WDCU
Old 07-19-2007, 07:58 AM   #11
Van
Profile:  1977 23' Safari
Hillsboro , Oregon
I have found "the wife" option to be very expensive and not just financially.
Van
2005 F-150 FX4, SC, 4X4, 5.4 V8
'77 23' Safari
Van is offline   Reply With Quote
Old 07-19-2007, 08:13 AM   #12
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Helena , Montana
Ok how about the husband? I back up without the help of a camera or a husband.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 07-19-2007, 08:13 AM   #13
ArtStream
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Cheers
Andy at Inland RV swears by these cameras. He was testing one a while back, is this the same model?
Michael
ArtStream is offline   Reply With Quote
Old 07-19-2007, 08:48 AM   #14
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Michael
Same one.
Some said you cannot leave them on very long.
We put one thru a continuous 500 hour test. (Three weeks).
Worked just as well after as it did at the beginning.
Every Airstream owner that backs their rig up, should have one.
They are cheap compared to paying an insurance deductible along with the inconvenience of having the trailer in a shop for body work.
But it's like insurance.
It's useless, "UNTIL" you need it. Then it's worth far more than it's cost.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 35 07-27-2008 10:38 PM
Homemade backup camera 83Excella Airstream Trailer Forums 28 08-17-2005 12:31 PM
Wireless backup camera gklott Electronics & Connectivity 5 01-11-2005 12:23 AM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
Powered by vBadvanced CMP
