Old 11-25-2013, 07:19 PM   #1
1998 25' Safari
Clayton , North Carolina
Wire short
The red rear clearance light on the trailer apparently developed a short and has melted the rubber coating on the wires. These are two single black wires and when you plug the connector to the tow vehicle they are now really heating up. I am not sure how far this has affected the wiring but really need to gain access to these wires or at the very least need to cut power to this light and rewire. Any suggestions? Thanks 98 Safari 25
gillikinsh is offline   Reply With Quote
Old 11-25-2013, 08:47 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Don't plug in again until resolved.
Do u have schematic?
I suspect it is fed from tip light.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-25-2013, 08:56 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The trailer clearance lights circuit have their own fuse. Take that fuse out and replace the wire, which is not simple, because it goes through the wall.
Old 11-25-2013, 11:04 PM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
check to see if the fuse is the correct rating - if it is enough amperage to heat wires and soften insulation the fuse should* be opening (in a perfect world).
