Old 09-29-2019, 02:29 PM   #1
1977 31' Sovereign
Dorr , Michigan
Wire retention clips
I am in the process of the teardown of my 1977 Sovereign and i have 80% of the interior skins removed. I noticed the 2 seperate main runs of wires on each side of the vents (120v and 12v) and how they are retained with metal clips. I noticed around every 3rd rib has one of these clips and i know with the skins on they really dont have a whole lot of functionality but does anyone know if you can buy these somewhere.
crazycuda is offline   Reply With Quote
Old 10-02-2019, 06:11 AM   #2
1976 31' Sovereign
Jacksonville , Florida
I actually drilled two holes and used a wide zip tie. Don't over tighten it and it will be fine.
Andy Moreau is offline   Reply With Quote
grey stick-on wire clips Chuck Electrical - Systems, Generators, Batteries & Solar 4 09-22-2016 08:03 AM
Awning retention hook gone, would you replace? MN Jeff Awnings 36 06-07-2016 06:15 AM
Rusty Rear Awning Retention Struts – SOLUTION withidl Awnings 7 01-03-2014 04:40 PM
Frame Rust/Belly Pan Moisture Retention?....2000 and Later Year ASs???? TomR Repairing/Replacing Floor &/or Frame 23 10-30-2009 11:17 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
