Old 05-18-2006, 10:02 AM   #1
AnnabeltheCaravel
chalcedon's Avatar
1967 17' Caravel
wire question.
Good day.
When i pulled the rotten floor up from our 67 caravel, there was a small metal box thing about 1 or 2 inches long by about 1/2 inch wide or so connected to some of the wires comming from the wiring harness ; this little connector thing was screwed to the bottom, (underside) of the floor in the front of the trailer.
What was that thing? Am i correct in assuming that it was an automatic restet circuit breaker. If so, what amperage did this thing have?
and to which wires was it connected.
I should have written all of this down, but at the time i was thinking of rewiring the whole thing from scratch.
Thank you all who have answered my silly questions so far!!
Eric...
chalcedon is offline   Reply With Quote
Old 05-18-2006, 04:17 PM   #2
1966 17' Caravel
Seattle , Washington
Send a message via AIM to kitchenclose
Humm, I'm looking at the owners manual and I don't see what you are referring too in the book.
At first I thought it was the transformer but that's located near the back by the closet. In my diagram, the connections at the front would be for the water pump or the lights.
Let me know if you need more info from my manual or purchase one from Secretarial Services 937-492-8885
Karen
PS - Since you are replacing your floor, you may want to protect your new floor w/ Rot Doctor. I just coated my floor w/ it. Works great.
kitchenclose is offline   Reply With Quote
Old 05-18-2006, 04:19 PM   #3
1966 17' Caravel
Turning the pages of my manual, How long is your caravel? That makes a difference on the layout.
K
Old 05-18-2006, 05:35 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
May I suggest a digital camera...allbeit a bit late I take pictures of everything before I disconnect or disassemble. There was a circuit breaker/fuse for the brakes. But not sure when that started. In the 70's there was a anti sway device that would apply trailer brakes automatically if sway started. I have the wiring diagram for 1975 but have never seen one in person...yet.
Aaron
WBCCI #XXXX AIR #2495
Old 05-18-2006, 07:04 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I have one of those under our Overlander. It is a 20 amp breaker.
Looks kind of like: [**]
Old 05-19-2006, 06:50 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Originally Posted by chalcedon
Good day.
Eric,
Do you still have this so you could post a picture of it?
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 05-19-2006, 12:49 PM   #7
AnnabeltheCaravel
chalcedon's Avatar
1967 17' Caravel
Well, after about an hour of searching through the garage, i found the mystery piece.
Looks like a circuit breaker of 25 amps.
Would this be for the brakes?
Thanks for the replies!
Eric...
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Extra wire susan martin Batteries, Univolts, Converters & Inverters 3 09-21-2002 07:52 AM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 08:25 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
