Old 07-10-2016, 10:59 AM   #1
1973 23' Safari
1970 27' Overlander
Boerne , Texas
wire question
Working on figuring out my wiring and getting things reconnected. The below pics show yellow wires that went from a 12v outlet on the street side of my Safari to this small circuit board (?) on the curb side. The antenna also connected to this board as well as a wire from the old radio. I've am not going to use the antenna - that is already out; also getting a new radio. I am thinking I do not need this circuit board looking thing and was just curious what it was and why this wire is so different than all the others.
Greg
ID:	266376   Click image for larger version
Name:	yellow wire and circuit.JPG
Greg1410 is offline   Reply With Quote
Old 07-10-2016, 11:40 AM   #2
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
Probably the antenna booster/amplifier.
Dennis
dennis3751 is offline   Reply With Quote
Old 07-10-2016, 10:19 PM   #3
1979 23' Safari
Wayland , New York
It's old antenna wire and signal booster. Old antenna would have gone in front street side corner by the wing window, if it was installed. I had the same think in my 79 safari. Pretty sure I ripped it out when cleaning up all my wiring.
Figure out where you'll put a new antenna for the new radio. Having one inside the trailer gets poor reception. They make flexible tape antennas but it really needs to be by a window for good reception the need to be able to get the wire to the back of the new radio.
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 08:18 PM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
wire question. chalcedon Electrical - Systems, Generators, Batteries & Solar 6 05-19-2006 12:49 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
