10-11-2006, 04:08 PM
1986 32' Excella
vledder
, drenthe
wire diagram 1986 32 exella
Where can I find the wire diagram for the car to trailor conector for a 1986 32 exella.
Is this a 7 or 9 pin plug?
Remco
10-11-2006, 05:04 PM
1973 Argosy 26
Norristown
, Pennsylvania
Reply to "wiring diagram for 32 Excella
Hi There: Standard wiring carries a seven "flat blade" round conector. I do not know of any nine pin connecting plugs. Be sure to check location of wires to coresponding pins. I believe that AS locations are different from US standard truck manufacturers wiring. Atleast it was that way on older units. Best to ring them our first. Good luck, "Boatdoc"
10-11-2006, 06:53 PM
INSANITY CENTRAL
1986 32' Excella
Airstream Funeral Coach
Citrus Heights
9 way plugs 86 excella
Search the title above. I made a few posts I have a 86 excella with a 9 pin. There are 2 different 9 pins as I describe, do yourself a favor and convert to a 7 pin. Smooth sailing Tim
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
10-12-2006, 04:10 PM
1986 32' Excella
vledder
, drenthe
thanks.
Think that I wil take some euro conectors with me to the harbour when we go to pickup the AS.
If the plug is not good just chance to European plug on the spot.
Are the colors of the wires coming from the trailor alwas the same?
Remco
10-12-2006, 05:10 PM
INSANITY CENTRAL
1986 32' Excella
Citrus Heights
All you need to get home is stop turn and tail, running lights. I wouldn't consume a lot of time at the dock, you know it's busy there and why hurry yourself. So good luck, Did you get manuals with your rig? If you have more ?s you could pm me. seeing as we have the same trailers.
www.popasmoke.com
YETI ( 65 Quart )
10-14-2006, 09:06 AM
1985 25' Sovereign
Bremerton
I have a nine pin
My AS is a 85 25' Sovereign (sp?). It has a nine pin and I have a daigram. I would have to scan it. So let me know if you need it.
In my AIRSTREAM, I'm at home!
Fred & Trish Allman
10-14-2006, 10:48 AM
2002 25' Safari
Dewey
This picture is from the Airstream web site at http://www.airstream.com/product_lin...rvice/faq.html
This site has alot of great information
Richard
10-14-2006, 12:27 PM
INSANITY CENTRAL
1986 32' Excella
Citrus Heights
espresso drinkers rule
Richards got it right!! Thats the same diagram in my manual and exactly the way my trailer and TV are wired. The big-longer- pins are at 3 and 9 oclock, not so in some of the newer round pin 9's. But you will probably chop that plug off anyhoo. Thanks for seconding my motion Richard! Tim
www.popasmoke.com
YETI ( 65 Quart )
10-14-2006, 01:21 PM
1986 32' Excella
Birmingham
, Alabama
I was reading your post. I also have a 1986 32 foot Excella and I have the manuals. What portion do you need? I will be happy to reproduce that portion for you for the cost of copying. In fact, I will be happy to take the whole lot to Kinko's if you will foot the bill.
hlagman
10-15-2006, 02:47 PM
1986 32' Excella
vledder
, drenthe
Thanks for the info!!
Remco
