Old 09-14-2016, 01:15 PM   #1
2015 20' Flying Cloud
Fort Mill , South Carolina
Winterizing
I live in South Carolina and although we get some freezing temps in Jan-Feb, it doesn't stay freezing for prolonged periods. Since I plan on using my AS through the winter months is it necessary to put anti-freeze in the system as long as I drain out all the water?
mikeljla is offline   Reply With Quote
Old 09-14-2016, 04:34 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
No, but I would probably put some in the traps and toilet to be on the safe side.
CRH is online now   Reply With Quote
Old 09-14-2016, 05:41 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Many answers and it depends how cold, for how long, and what kind of chances you're willing to take. Plumbing damage from freezing can be expensive and time consuming to fix. I had to replace a toilet once even though I had blown out everything with air.
If I were in your situation I would consider keeping the trailer warm enough with some supplemental heat to reduce the chances of damage. That will also keep the humidity down and help keep everything fresh. If you keep the interior at 45 degrees you should be good down to 20 degrees outside temps as long as the trailer is out of the wind. No guarantees, but that's what I would do
Air pressure for winterizing montanaandy Winterizing, Storage, Carports & Covers 19 10-19-2018 11:33 AM
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 07:50 PM
Winterizing question PatCrusse Our Community 15 11-14-2002 01:08 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 10:27 AM
What can happen w/o Winterizing Craig Plumbing - Systems & Fixtures 1 09-23-2002 10:10 PM
