Old 10-19-2014, 08:56 AM   #1
1986 25' Sovereign
Cincinnati , Ohio
Winter battery storage
I have just purchased an '86 25' sovereign with two batteries. Do folks recommend removing batteries as part of winterization? If so, do you recommend a trickle charge system for the batteries over the winter months?
Steve
Ssmookler is offline   Reply With Quote
Old 10-19-2014, 09:12 AM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
I remove my batteries during winter. I store them in an attached garage, which stays above freezing during the coldest weather. They sit on a piece of 2x12 on the garage floor attached together in parallel, and are charged with a smart battery tender.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-19-2014, 10:01 AM   #3
terryV's Avatar
2002 31' Classic
Monroe , Iowa
For many years I have just left them in the unit, hooked up to a Battery Tender. It seems to work just fine that way.
terryV is offline   Reply With Quote
Old 10-19-2014, 10:21 AM   #4
aftermath's Avatar
Spokane , Washington
I have to store my trailer in a lot without access to power. It gets very cold where I live so I put mine in the basement and monitor them. I charge them about every 4 to 5 weeks.
If you can plug yours into a trickle charge you should be fine. A charged battery will not freeze, or so I have heard.
aftermath is offline   Reply With Quote
Old 10-19-2014, 11:12 AM   #5
1974 Argosy 20
Kooskia , Idaho
I have said this many times in the past, but here is another repeat. All you need to do is this for winter storage is:
1. Be sure the batteries are fully charged.
2. Clean the tops of the batteries.
3. Disconnect the wires from the negative terminal(s) so that there is absolutely no way the batteries can be connected to anything and be discharged.
There is no need to remove them. There is no need to trickle charge them. They will not freeze if it is above -40 F. Battery self discharge is increased by them being nice and warm. When cold, the rate of self discharge is decreased.
In the spring, re connect the negative terminal, and use the built in converter/charger in the Airstream to bring what little discharge that has occurred back in.
I have had Airstreams since the late 1970's and this technique has worked very well for all of those years. I have never had any battery damage. My battery life is in the range of 8 to 10 years.
And others will disagree with me. But charge, clean, then fully disconnect will work just fine in any cold climate. No need to break your back removing batteries.
Old 10-19-2014, 03:34 PM   #6
1986 25' Sovereign
Cincinnati , Ohio
Battery winterized
Thanks for your comments. Leaving them in the AS seems so anti-intuitive.....
Winter Battery Storage "How To" DreamsInSlvr Winterizing, Storage, Carports & Covers 30 10-08-2017 09:19 AM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 10:17 AM
Winter storage whizguy Our Community 13 11-02-2004 12:16 PM
Winter Storage Scaler113 Winterizing, Storage, Carports & Covers 4 10-13-2003 08:31 AM
Outside winter storage question rfield54 Winterizing, Storage, Carports & Covers 16 09-12-2003 01:17 PM
