Old 04-03-2017, 09:35 AM   #1
2015 25' FB Flying Cloud
Minnetrista , MN
Will group 27 battery fit?
I have a 2015 Flying Cloud 25FB and currently have group 24 flooded batteries. Has anyone found a good AGM group 27 battery that will fit in the battery box?
Wesair is offline   Reply With Quote
Old 04-03-2017, 10:38 AM   #2
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
Word is that 27's fit if you rotate placement, from inline to crossways. May be specific as to which spot fills first and the center rod may need to be removed and reinstalled in the process.
I haven't replaced my batteries yet, so I don't know for sure, but the word is, , ,
"Chip Tank" is in Vacaville Ca.
CDONA is offline   Reply With Quote
Old 04-08-2017, 08:44 PM   #3
On adventure with H&G
MattB's Avatar
2012 30' Flying Cloud
1966 28' Ambassador
Lansing , Kansas
I tried today and came up about 3/8" too short after taking off the lid completely. If you could trim the lip on the front of the steel box that that lid is riveted on to, it would make it.
Hope this helps. I didn't try it sideways, but that seems unlikely.
Regards,
Matt
MattB is offline   Reply With Quote
Old 04-08-2017, 08:59 PM   #4
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Look at dimensions of Trojan 27AGM. Fits our battery boxes with room to spare compared to previous flooded Group 24s.
Alumacoot
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 04-08-2017, 09:47 PM   #5
AirstreamCSH's Avatar
2016 25' Flying Cloud
Huntington , New York
I went the route of two Lifeline 6V AGM's and they fit my 2016 25FB battery box perfectly.
AirstreamCSH is offline   Reply With Quote
Old 04-08-2017, 09:50 PM   #6
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I have 2 group 27 lifelines in my battery box....
It's a 2008 25'....
wulfraat is offline   Reply With Quote
Old 04-08-2017, 11:02 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You can go even larger. I put two 12 volt Lifeline AGM GPL 31XT batteries in our FC 25. I removed the lid, trimmed away the forward lip with a sawsall, dropped the batteries in, and riveted the lid back on at the sides. You will need much larger cables for the parallel connection between the two batteries than the stock cables, to ensure there is absolutely no resistance between the batteries. The center battery hold down rod will be tight between them.
Doug and Cheryl
Old 04-09-2017, 06:36 AM   #8
@Wulfraat - Nice install. did you torque the bolts or hand tighten?
Old 04-09-2017, 07:58 AM   #9
Did some homework on these group 27's and added them to my spreadsheet. Wish I had thought of this a week ago as these seem to have an extra hour of runtime over the 6V.
Old 04-09-2017, 09:18 AM   #10
dkottum's Avatar
wulfraat, would it be better to have the two parallel leads of the same size (large), and short as possible? I believe the idea is to parallel the batteries so they act as one large battery, with as little electrical resistance between them as possible.
It looks like you have the same space issue we have with our two Group 31XT, the batteries fit too close together for the hold-down rod to fit easily.
Doug and Cheryl
Old 04-09-2017, 10:53 AM   #11
wulfraat's Avatar
My batteries are connected in parallel with 2 leads of the same size (2ga I believe).
I agree that cables in theory should be as large and as short as possible.
I may try and put some larger / shorter parallel cables in there this year (maybe 0/1 or 0/2) but I don't draw heavy amps from those batteries even with my inverter (I don't run the microwave for instance, just the TV, phone chargers, laptop,etc).
For light loads I don't think it matters much.
Bolts are tightened down good using a wrench (not hand tightened)
I removed the tie-down rod as there wasn't room for it.
Once these puppies are done I am going to make the move to lithium, 300-400 amp hours, and move my battery bank indoors. I boondock a lot and get tired of constantly monitoring and worrying if I am drawing down towards the 50% mark of my AGM bank.... (I have a victron 702 monitor in my system)
group 24 or group 27 rochar3 Batteries, Univolts, Converters & Inverters 8 12-14-2015 04:37 PM
Group 24 to Group 27 Batteries in my 27ft International BoldAdventure Batteries, Univolts, Converters & Inverters 8 02-26-2015 08:52 PM
Group 24 to Group 27 handn Batteries, Univolts, Converters & Inverters 2 06-07-2014 07:42 PM
Help-Group 31S vs Group 27 Battery Question trevisgardne Batteries, Univolts, Converters & Inverters 4 06-10-2009 09:32 AM
Battery Group BA Sovereign 1974 - 1979 Sovereign 4 09-16-2003 11:28 PM
