Old 06-30-2017, 06:03 PM   #21
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
Originally Posted by JMynes View Post
I have done exactly what you speak of and got away with it for the most part.
The 20 amp breaker would occasionally trip. No big deal, right?
Well, at 1AM I decided it WAS a big deal. I put in a Micro-Air Easy Start and it fixed that problem.
I would watch for voltage drop in the trailer. On one outside outlet in the rear of the house I needed an extension cord and got concerned when I saw 104 volts in the trailer (AC running). I plugged in to an outlet in the front of the house, same circuit but much nearer the service panel, and eliminated the extension cord. Now the lowest voltage I see is 118 (AC running).
I'll look into the Easy Start. In one respect I'm lucky since the outdoor outlet on my garage is directly adjacent to where I park the trailer and is no more than 10 feet from the power panel. I only use the trailer power cable and a dog bone. I'll monitor the voltage at the trailer to be sure. Thanks.
“The thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin (sold)
2020 25' Globetrotter Twin (here!)
2017 F250 4x4 6.7 max tow Platinum
mikeinca is offline   Reply With Quote
Old 07-01-2017, 11:01 AM   #22
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Will an A/C work at a 15 amp service camp site?
Originally Posted by wulfraat View Post
Typical 13.5k or 15k but AC draws just over 16amps
Well I guess that is the rated draw on a hot day.... I was able to run my Ac yesterday (with an easy start, 75 degrees outside) on 15A service. Nothing else in the trailer running....
I was wrong
wulfraat is offline   Reply With Quote
Old 07-01-2017, 11:12 AM   #23
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The earlier posts raise an important point. First, the Easy Start is not only going to reduce the starting current but its protective features will block against low voltage. If you just run your AC on a 15 or 20 amp circuit and it does not trip on starts you should still monitor the voltage. Low voltage means higher current and that will reduce the life of your compressor motor, if you care about that. I am not qualified to say exactly what voltage level should bother you. This is always a concern, even with a 30 amp connection, in crowded campgrounds.
Larry
lsbrodsky is online now   Reply With Quote
Old 07-01-2017, 11:15 AM   #24
wulfraat's Avatar
The easy start needs to see a pretty big drop in voltage before it cuts off the current - in my tests at altitude it would only cut off the compressor around 95volts. I'd have to check the plate on the AC unit but I think it wants to see 115 volts per its spec. I don't think I'd want to run it below 110v
Old 07-01-2017, 08:57 PM   #25
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The only *good* way to find out if the load is to much for the supply circuit is to measure it with a meter. Depending on safety devices to measure it for you is not the best way. Surprisingly, breakers are only rated for a pretty low number of "cycles". That's why you don't use then as switches.
Lots of fun !!
uncle_bob is online now   Reply With Quote
Old 07-17-2017, 03:16 PM   #26
1968 26' Overlander
Miami , Florida
This thread has pretty much died out, but FWIW we just finished 3 weeks on the road with our Tradewind, and I found that a 15 amp service would run the A/C as long as everything else including the converter was turned off, with minimal voltage drop. (My AC power panel is Blue Sea System with built in digital multimeter.) This requires using the 30 amp power cord all the way to the power outlet, and a CLEAN 15 - 30 converter plug at the outlet.
Using a cheap 16 gauge extension cord, (which I tried once when the outlet was too far from the trailer) you will definitely see a voltage drop as the cord heats up.
TurkeyRun is offline   Reply With Quote
Old 07-17-2017, 08:17 PM   #27
ITSNO60's Avatar
Tucson , AZ
Larry
Motors are rated with a 10% + or - factor per UL standards. A motor rated at 115 volts can operate at 103.5 to 126.5 volts. Would I want to run my AC at 103.5 volts? No, but that's the accepted industry standard.
ITSNO60 is online now   Reply With Quote
Old 07-18-2017, 11:48 AM   #28
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I see a current draw of 14.7 amps when the 13.5K A/C is running in our 2015 23D International Serenity in our RV park. That does not reflect the current draw during startup.
A Rigid Industries (or equivalent) #10 wire 25' extension cord could be used with the short 30 amp to 15 amp pigtail from Furion into a in good shape 20 amp rated outlet. Everything else in the trailer would have to be off that can be turned off including the Airstream installed converter.
Service snafu $&!&& and which battery is which amirm Sprinter and B-van Forum 25 07-04-2016 10:19 PM
Need a camp site near Lexington KY...any ideas? caberneigh On The Road... 3 04-07-2011 09:12 PM
Buying a Camp Site Kathleenh On The Road... 41 01-06-2011 04:34 PM
Camp site wiring?? pawnguy Electronics & Connectivity 9 09-24-2010 10:02 PM
Camp Site Signs To Help An Adoption Chaplain Kent Off Topic Forum 5 03-13-2006 10:42 AM
