Old 05-28-2015, 06:55 PM   #1
Olympia , Washington
WiFi Ranger on 12 volt power or 110
I have a question about WiFi ranger system {https://www.wifiranger.com/shop/product/52-elite-pack-flat-mount}. We are getting it installed tomorrow on our 2015 30-ft Airstream Flying Cloud.
This is the email I got from service tonight, "Do you have an objection to the wifi booster being hooked up to 12 volt power instead of the 110? It does give you the option, however for the 110 to work we would need to run a significantly larger amount of wire to get it to a plug. The booster if hooked to 12 volt would work basically anytime your battery booster is engaged. This is the way we have done on the other trailers we have installed it on and have not had an issue. "
I tried to call service but they are gone for the night and I need to get them an answer by the morning, since I'm the first job.
Can someone help me understand what he means by battery booster? We are complete newbies so I'm not sure which option to choose - 12 volt or 110. I just know I need this to work at all times - as I'll have to work online on the road.
Anyone have the WiFi Ranger system and want to chime in?
Thank you!
AirstreamBee is offline   Reply With Quote
Old 05-29-2015, 04:20 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I have one and have it connected to 12v so it will work all of the time. I can disconnect it and reconnect it to 110 AC but I cannot see a need to do that.
Larry
lsbrodsky is offline   Reply With Quote
Old 05-29-2015, 06:07 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Connecting to 12 volt is actually preferred to 110 volt because that way it will work even when you are not connected to shore power (or a generator.) In general, when presented with a choice to connect a device to 12v or 110v pick the 12v option.
Bob Martel
WBCCI# 5766
Old 05-29-2015, 08:16 AM   #4
2016 30' Classic
Erie , Colorado
Third vote for 12V power.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 05-29-2015, 08:52 AM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Mine has been directly wired to the 12 volt bus for 4 years now. I have never plugged it into 110 yet!
Old 05-29-2015, 10:54 AM   #6
Parker , williamdcrockett
Like everyone else mine is on 12V. I do not have any reason to use 110V for it.
wcrockett is offline   Reply With Quote
Old 05-29-2015, 11:41 AM   #7
Boxite's Avatar
2008 22' Sport
Additionally if connected thru 12 volt you will automatically have the advantage of power-line conditioning. In other words, if you ever run on a portable generator, the 110 volt supply might be capable of damaging any digital equipment due to power-fluctuations.... while running on 12 volt automatically pre-conditions (smooths) the power source. (The 12 volt battery is essentially a huge capacitor/condenser and will provide electronic shock-absorbing for your digital electronics.)
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 05-29-2015, 04:20 PM   #8
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
There seems to be many models from which to choose. Are most AS owners going with the external antenna models?
DoublTrouble is offline   Reply With Quote
Old 05-30-2015, 04:12 AM   #9
lsbrodsky's Avatar
I have the external antenna model and it is not permanently mounted. I have it attached to a telescoping pole(deck brush tool) which fits inside a pvc pipe attached to the wd jack on the trailer. The 12 v power supply is in the battery box and I simply plug into that. It gives me a very strong signal inside the trailer and if the campground wireless is strong enough I do not erect the unit.
Larry
12 volt
WiFi Ranger master thread Gene Computers, Internet & Satellite 174 08-14-2015 11:42 PM
Adding 110 volt and 12 volt outlets Bikerbill Sprinter and B-van Forum 2 02-13-2014 06:22 PM
Need Assistance With WiFi Ranger Sky Hibby Computers, Internet & Satellite 8 09-06-2012 08:11 PM
OK to Run AC on house 110 volt? Chasmorgan Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-30-2009 08:03 AM
external 110 volt outlet door-curbside Kirby Stone General Repair Forum 0 01-21-2004 01:41 PM
