Old 02-17-2011, 03:48 PM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Why trailers burn
Nearly all RV fires are of electrical origin, despite the recent attention to fridge fires (which are statistically still quite rare).
What are the failures that most commonly lead to such fires? What can we do to prevent them?
Old 02-17-2011, 05:00 PM   #2
tpi
Trabuco Canyon , California
Question I have is the main positive cable running off the battery, where is the first fuse/breaker on that wire? How far through the trailer does it go unfused?
On the 120 volt side maybe termination of the outlets when running high draw heaters, etc.
tpi is offline   Reply With Quote
Old 02-17-2011, 05:34 PM   #3
Central , Mississippi
An eye opener is to walk thru an RV salvage lot, like Cowas...Lots of BBQ'd RV's from the dash and rear engine area...I don't recall seeing any trailers though...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-17-2011, 05:40 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I'm curious about how many vintage trailers have electrical fires caused by the old aluminum wiring. I was unable to rewire my trailer when we did the shell-on floor replacement, so when I needed a new outlet, I was told to use one made for aluminum wires. So I stole an outlet from back in the bathroom, which I didn't need, and installed it next to the new converter. But I do wonder how much risk there really is in the old wiring in my trailer.
Stephanie
Old 02-17-2011, 05:46 PM   #5
DougZ's Avatar
1972 27' Overlander
Venice , Florida
Many times during the week I go out and sit in my AS. Sometimes I wonder how it has lasted 38 years and if it will die on my watch. I have fused many of the wires and replaced a lot of the LP gas pipes to prevent this from happening. I bought new smoke detecters to install but they won't do much good if no one is in the trailer. I think my next preventive maintenance is to get rid of the old humm box and put in a state of the art unit. I sure would hate to be the one that lets this beautiful trailer go up in flames.
Doug
DougZ is offline   Reply With Quote
Old 02-17-2011, 05:49 PM   #6
_
?? it seems u asked pretty much the same question 366 days ago...
http://www.airforums.com/forums/f48/...ler-61322.html
most of those links i posted then are still good and relevant.
mohos have primarily engine/driveline/exhaust related fires...
trailer's are either operator error ((cooking, over loaded juice, old gadgets, extension cords and so on...))
or electrical, or occasionally propane related...
these are also worth reviewing...
http://www.airforums.com/forums/f42/...eam-46861.html
http://www.airforums.com/forums/f44/...eam-56617.html
http://www.airforums.com/forums/f449...ire-62810.html
http://www.airforums.com/forums/f368...ent-38772.html
as are these...
in fact there is a SPECIFIC and long term a/s engineered fire risk noted and solutions posted here...
http://www.airforums.com/forums/f353...afe-39545.html
and discussions of 'plans' to escape, prevent, avoid...
http://www.airforums.com/forums/f161...lan-15084.html
http://www.airforums.com/forums/f161...ted-17997.html
it's all important stuff and a lot of good things have been posted...
cheers
2air'
Old 02-17-2011, 06:56 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Okay, I'll tell you about a little-known fire hazard on some 1970's model Airstreams. One you wouldn't even think about. I didn't, until I set an Overlander on fire with it.
Now that I have your attention, how many of us with that era Airstream have the umbilical receptacle in the front of the trailer, behind the LP tanks? How many of them are the original, kind of grey-ish, plastic-y looking ones?
Guess what I found out.
They aren't plastic.
They're magnesium.
That's right.
The stuff they make highway flares out of, because it ignites easily, burns bright, AND YOU CAN'T PUT IT OUT!!! Water makes it much worse.
I set a trailer on fire by the simple act of cutting off the rusted-on mounting bolts with a cutoff wheel. The wheel made the magnesium hot enough it ignited. I got a nice, red flame from it.
You never saw somebody move as fast as i did running inside the trailer, throwing aside the gaucho cushions, nipping the smouldering wires off it, and kicking it outside the trailer, where it continued to sizzle and spume.
After my heart started beating again, I called the boss over, showed him the flaming plug, and gently misted a small amount of water on it. It flared up immediately, it's good it wasn't still on the trailer, or it would have become an aluminum marshmallow.
Old 02-17-2011, 07:01 PM   #8
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Terry,
Are the new ones the same construction?
Bill
They're magnesium.
That's right.
Just my personal opinion
Old 02-17-2011, 07:04 PM   #9
Well Preserved
1993 21' Sovereign
Originally Posted by wkerfoot View Post
Terry,
Bill
No, the new ones are aluminum or pot metal. Non-ignitable. The only plastic ones are pretty obviously black plastic. Now you know why the fire department was at the shop in Riverside a year or so ago...
Old 02-17-2011, 07:10 PM   #10
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
Fire Extinguishers
We receive our new AS next week! Hooray!!
As with our fiver we will carry an "extra" ABC extinguisher on the inside under the sink, and another stored on the outside compartment, probably on the side of the AS.
I certainly will watch for the hot wire from the battery system to the main jack, and enclose it if necessary.
Great thread. Thank you....Zigi
Zigidachs is offline   Reply With Quote
Old 02-17-2011, 07:22 PM   #11
until I set an Overlander on fire with it..
Ummmm... Terry...? That was a CLIENT'S Overlander, right????
Old 02-17-2011, 07:44 PM   #12
Baltimore , Maryland
considering the aluminum wiring was only one year, very few due to aluminum wire.
Old 02-17-2011, 07:55 PM   #13
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
The aluminum wire in my 67 is just fine...Im not planning on replacing it either. Im NOT running an high demand appliances in it either...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 02-17-2011, 07:57 PM   #14
Well Preserved
1993 21' Sovereign
It was a '77... Looked like it had been dredged up out of the bottom of Lake Elsinore...
Capt. Wilson's 1959 Overlander nmbosa 1954 - 1959 Overlander 309 05-09-2016 01:18 PM
Airstreams and leaks Julie B Leaks - Weatherstrips, Gaskets, Caulks & Sealants 71 07-13-2012 04:38 PM
Need spec info on what trailers are made of......... funhouse Buyer Guidelines 25 03-05-2011 06:51 PM
Airstream Mini TWaugh Off Topic Forum 18 01-16-2011 08:21 AM
