Old 09-11-2005, 11:58 AM   #1
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Why are my brake lights so dim?
The brake lights on our '75 Trade Wind are extremely dim?
I removed the lensís and cleaned the plastic. Looked at the bulbs, they are fine.
I found that the outside, 1156 (dual element) socket not to be wired with both legs going to power. The inside light (1157 single element) shoed fairly bright but, not very with the lens on. I spliced power to the outside element to the via the inside slice, however this reduced the light to near nothing????
Any ideas?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 09-11-2005, 01:04 PM   #2
Tinsel Loaf's Avatar
Do you you have 12 volts at the socket? If so a bad connection could cause a vlotage drop under a load. Check the voltage at the tow vehicle plug for the rear lights under load it should be 12 volts. If you have 12 volts at the lamps but they are dim you may have a bad ground.
Tinsel Loaf is offline   Reply With Quote
Old 09-11-2005, 01:15 PM   #3
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
I had the same problem with my 77 Caravanner, I took the lens off and checked the power and had full power, still was dim, so I took the lens off my car and compaired them, they were the same brightness with just the bulb hangin out,still didnt have that warm and fuzzy feeling,so I painted the inside of the bulb holder white,still not the best results,,,,,,,, so I went to Carquest and bought LEDs for boat trailers for $49.00 did some fancy fileing and they look awesome!!!! its the only way to go , total of $100.00 and I feel so much better about putting on the brakes,
scf31 is offline   Reply With Quote
Old 09-11-2005, 01:25 PM   #4
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Hmmm That could be, it is old wiring, some of it may be corrosion, I'll have to dig out my multi meter I think, thanks, that din't even occur to me!
www.balrgn.com
Old 09-11-2005, 01:38 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
balgrn
make sure you check the ground connection on your tow vehicle.
everything on your trailer could be in perfect order, a bad ground at your tow vehicle plug could cause the problem.
a quick and dirty way to check would be to apply 12v to your clearance light circuit. do this at the cord on your trailer. just jumper between the battery charge line pin and the clearance light pin.
if they light up as they should start looking at your tow vehicle. if they do not get brighter the problem is in the trailer itself.
john
you call them ferrets, i call them weasels.
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
Brake Controllers smily Brakes & Brake Controllers 6 10-02-2002 06:12 AM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
