Old 09-09-2002, 03:10 PM   #1
Which switch is which or what
OK. I'm sure this is an easy question for someone...
On the interior left of the door in my 74 Sovereign, there are two switches. One of them works the exterior door light (which needs to be rewired) and the other one?????? I have tried flipping it but nothing happens. Something else to be rewired??
Thanks!!
74Sovereign is offline   Reply With Quote
Old 09-09-2002, 03:14 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The second switch may be for the other exterior light???
The one I mean is in front of the curbside window and round. There may be a switch for it nearer the light itself, sometimes behind the drapes.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-09-2002, 03:53 PM   #3
1975 31' Sovereign
Eau Claire , Wisconsin
In my '75 one of the switches is for the light over the sink which is a three way; one position is on, one is off ,and one allows it to be controlled by the wall switch. Maybe that will help.
Brouck Sleight
bhsl8 is offline   Reply With Quote
Old 09-09-2002, 09:59 PM   #4
2002 34' Classic S/O
Irvine , California
Images: 11
In my 75 Overlander the second switch works the light over the kitchen. You need to play with the switches in multiple positions until you get it the way you like.
Phil in Irvine
WBCCI # 9759
2002 34 Slide Out Lounge
2005 Yukon XL, 3/4 ton, 4WD, 8.1 engine
pjtaia is offline   Reply With Quote
Old 09-10-2002, 08:31 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yes, and it took me a while to figure this out, because it isn't really a "3-way" switch. a real 3-way switch will operate a fixture from either switch, and this doesn't; it turns the power on and off to the switch on the light fixture over the sink, but not to the fixture itself. If the switch on the fixture over the sink is in the "on" position, then the switch by the door will turn the light on and off. If the switch on the light is in the "off" position, the swtich by the door appears to do nothing.
Old 09-10-2002, 08:45 AM   #6
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
What Chuck described is pretty much how the switch works in my 31' Excella. I have 2 switches on the right hand wall as you open the door. The upper switch is a 2 way on mine that turns on the lights over the kitchen sink (if they are turned on there). This makes it easy when entering at night. The lower switch operates my outside over the door entrance light. I also have another switch that is on the curbside wall just before you get to the curved panels that controls the flood light on the outside of the trailer. Hope this helps you out.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-10-2002, 08:55 AM   #7
Thanks for the great ideas!! Will check them out when I return to the "pod" this weekend!!
Help! Resistor on fan switch Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 22 12-20-2003 08:01 AM
electric couch switch Tom & Janet Salhus Electrical - Systems, Generators, Batteries & Solar 1 10-13-2003 04:53 AM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 03:09 PM
Break Away Brake Switch davespann Brakes & Brake Controllers 1 07-30-2003 08:22 PM
Light Switch JOECAR 1975-1976 Excella 500 1 03-16-2003 08:30 PM
