Old 10-20-2014, 10:45 AM   #1
2003 25' Safari
Roebuck , South Carolina
Which generator
I am going to purchase a generator and I expect it will be a Honda, either a ev 2000i or an ev2000 companion. I will be using it to power my 25 ft safari and to recharge my batteries when I camp where there is no shore power.
Which generator do you recommend?
Also, when using the generator, what is the best way to charge the batteries. I have a good battery charger that I use to recharge my trolling battery for my boat. Would using it be faster to directly plug into the generator or just use the camper connections through the main power cord?
charles
twoshotc is offline   Reply With Quote
Old 10-20-2014, 10:50 AM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
If you're going to have a single 2000, I would suggest the eu2000i. You'll want the 15 amp outlets. If later you want to power your air conditioner, then buy the companion. For charging batteries, simply plug in to the trailer (you'll need a 30 amp adaptor) and let the in-trailer converter/charger charge the batteries.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-20-2014, 10:52 AM   #3
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Why don't you try reading the numerous threads about generators that are already on here?
Al - K4GLU is offline   Reply With Quote
Old 10-20-2014, 11:16 AM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Many will recommend the Honda EU2000 but for a lower price the Champion 3100 seems a good bang for the buck. I don't have any personal experience.
75531i (US) - Champion Power Equipment
It's not so much larger than the Honda EU2000 and it weighs about 83lbs dry/93 with a full tank. You can run your AC on it and it costs a little less than the Honda EU2000. It starts an RV 13.5k AC while on Eco mode. t's a tad noisier. Search youTube for this and the Honda generators to get an idea of which is best for you.
Kelvin
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which generator to buy? nmex Generators & Solar Power 13 04-27-2007 11:38 AM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
