Old 09-29-2006, 08:07 AM   #1
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Where's the Charge going
Hi All
My univolt is working (I guess) as I get a charge of about 14 volts and control panel shows battery as pegged out good (green) after pluging into house, so I unplug and go out the following day and control panel shows Okay(yellow)? Nothing is on and battery is good. What is going on? Is it a short? I'd rather not replace univolt if I don't have to.
thanks for any info
James
The Flintstones is offline   Reply With Quote
Old 09-29-2006, 08:25 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by jsflint
Hi All
thanks for any info
James
James,
My 71's battery indicator was notoriously inaccurate. It did the same thing as yours, going to green when it was plugged in, and then showing yellow at rest without being charged by the Univolt.
It might have to do with the age of the instrument, or a grounding issue. The control panel lives in a fiberglass end cap, so good and solid ground connections are very important.
I'd say if there is no functional issue with your battery, just ignore the charge indicator, and use your volt meter to establish battery condition.
Uwe
www.area63productions.com
Old 09-29-2006, 09:02 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
No just Univolt
My '06 Safari has the Parallax converter and I see the same effect Uwe mentions. The battery indicator shows full green when plugged in to house current but a lower and probably more realistic amount when unplugged.
5 meter Langford Nahanni
Trailer Batteries 83Excella Electrical - Systems, Generators, Batteries & Solar 8 02-04-2013 11:57 PM
Charge Wizzard inthwind Electrical - Systems, Generators, Batteries & Solar 0 06-24-2003 10:16 AM
How to wire truck to charge TT battery? femuse Electrical - Systems, Generators, Batteries & Solar 19 04-09-2003 11:23 AM
Charge Wizard - Help! dmreilly10000 Electrical - Systems, Generators, Batteries & Solar 6 11-15-2002 04:37 PM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 06:49 AM
