Old 10-23-2015, 09:08 PM   #29
2015 28' Flying Cloud
Newtown , Pennsylvania
I have 2 eu2000 generators. I have used them in rain, snow, and sleet, uncovered. I have also used them when the sun is shining. Never had a problem.
Bruce
AstroBruce is offline   Reply With Quote
Old 10-23-2015, 11:14 PM   #30
martian's Avatar
2012 31' Classic
Naples , Florida
Bruce
Same here.
martian is offline   Reply With Quote
Old 10-24-2015, 09:19 AM   #31
dznf0g's Avatar
Oswego , Illinois
I know the title is about weather protection, and I agree that my Hondas are well protected as built....I just have a problem with my equipment sitting out in the elements....just my nature.
But, the tents do more than that...keep them better hidden....and, in the case of my SuperGen, reduce noise with panels sandwiched between the fabric. In addition, I had some leftover 1/4" Dynamat material from another project and used it in the walls of the tent as well. Reduces the noise of the already very quiet Hondas.
-Rich-
Old 11-09-2015, 09:09 AM   #32
2011 27' FB Classic
Camp Hill , Pennsylvania
My Honda 6500 owners manual is adamant about keeping it out of rain and snow. So this thread is useful.
LyleRussell is offline   Reply With Quote
Old 11-09-2015, 09:17 AM   #33
dznf0g's Avatar
Oswego , Illinois
Originally Posted by NC Camper View Post
This is a pretty nifty idea, https://youtu.be/anxI0RSq820, and it sure is cheaper than the $150 Supergen tent.
That's awesome...but I do have concerns. My research with talking to "gen tent" makers indicated there are some definite space requirements for ventilation and operating temp as it relates to coverings. That tent is definitely too small for proper operation of two 2000 watt gennies, and it doesn't look like it has a rear window???? I would definitely do some temp readings and investigate what your gennie mfr has to say about operating environment max temps.
-Rich-
Old 11-09-2015, 09:32 AM   #34
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Cover generator in rain
I use a heavy floor mat, hangs over the sides about 10 inches, use Velcro to keep it in place. And, as the sides droop a bit, the rain runs off. As my generator is near the AS, I have the electrical connection under the trailer, slightly off the ground.
Northern Tool Powerhorse 4000 ES Model# DFD4000
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 11-11-2015, 07:50 AM   #35
dznf0g's Avatar
Oswego , Illinois
Just as an FYI for those who don't protect the gennie while raining. This from the owner's manual for EU2000i:
"Using a generator or electrical appliance in wet conditions, such as
rain or snow, or near a pool or sprinkler system, or when your hands
are wet, could result in electrocution. Keep the generator dry.
If the generator is stored outdoors, unprotected from the weather,
check all of the electrical components on the control panel before
each use. Moisture or ice can cause a malfunction or short circuit in
electrical components that could result in electrocution."
-Rich-
Old 11-11-2015, 08:56 AM   #36
2004 30' Classic
Hillsborough , New Jersey
using the generator in rain
Place a fan (plugged into the generator) inside the tent and point the fan in such a way as to move the warm air toward the opening. wolf146
wolf146 is offline   Reply With Quote
Old 11-11-2015, 09:05 AM   #37
dznf0g's Avatar
Oswego , Illinois
If there's a mesh window in the back (can't tell if it's mesh or solid plastic), you probably don't need a fan...unless the wind is facing the tent opening and blowing the hot cooling air as well as the hot exhaust right back into the tent.
If there is no mesh in the back, a fan wil just pull that hot air from around the sides of the gennie and recirculate it back through the gennie cooling passages.
Of course, this depends on may factors: ambient temp, tent opening(s) size, tent overall size, etc.
My only reason for commenting is to encourage one to perform some experiments with a thermometer placed at the air intake end of the gennie (same end as the controls) until you are satisfied that there is no significant rise in temp in the back of the tent after prolonged use.
-Rich-
Its raining inside the AS Snedwid On The Road... 6 06-09-2011 09:51 AM
It's raining INSIDE! GRRRRR!!! Catman6 Full-Timing, Winter Living & Workamping 24 01-26-2011 05:19 PM
It's Raining INSIDE ncbambi Furnaces, Heaters, Fireplaces & Air Conditioning 6 09-28-2010 04:33 PM
It is raining and the truck wont start! memgrove2000 Tow Vehicles 19 05-03-2009 07:24 PM
raining inside gotair Leaks - Weatherstrips, Gaskets, Caulks & Sealants 24 01-26-2005 08:11 PM
