I'm installing a new battery operated carbon monoxide detector and a
12 volt hard wired propane gas detector in addition to installing separate battery powered smoke detectors.
The trailer I own had no detectors installed at all when I bought it.
Where are the carbon monoxide detectors and propane gas detectors commonly located?
The flammable gas detector location will be limited to areas where I can tap into existing
12 volt lines.
Are they typically located high? Low?
Thanks!
