Old 07-22-2006, 07:22 PM   #1
Grand Prairie , Texas
Where Is The Breaker Box 74 31ft.
Where Should I Look For The Breaker Box On My 74 31ft Sovereign?.with External 110 Power The A/c Works But Nothing Else Electrical Works.iput A Charger On The Battery And Most Of The 12v Electrical Works Without The 110 Power Plugged In.all That I Have Found Is A Blue Box Under The Sink Which Appears To Be An Intergral Battery Charger.
Mr. Know It None
Gpgopher54 is offline   Reply With Quote
Old 07-22-2006, 07:43 PM   #2
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Go Sit on the Toilet...
Then reach down with your right hand and slide the vertical, tamboured door open. Bend over and look at the back wall of the narrow cabinet you have just opened. See anything?
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 07-22-2006, 07:49 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Center bath or rear bath? In the rear bath it is in the very back of the cabinet to the right of the toilet when you are sitting on it. In a center bath it is located in the extreme rear left corner cabinet if you have a rear double, if you have the rear twins it should be in the wardrobe cabinet on the road side right across from the bathroom
Aaron
WBCCI #XXXX AIR #2495
Old 07-22-2006, 07:52 PM   #4
Alumaholic's Avatar
Images: 36
Dang it...
Originally Posted by wahoonc
Center bath or rear bath? In the rear bath it is in the very back of the cabinet to the left of the toilet when you are sitting on it. In a center bath it is located in the extreme rear left corner cabinet.
Aaron
Forgot to ask if it was a rear or mid bath. Snookered again.
Ken L
Old 07-22-2006, 09:07 PM   #5
Found The Box
Thanks I found the box with two breakers.One was marked with A/C the other was GfI ( something) Too obliterated to read.From the outside of coach I opened the access panel for the fridge but could not find the plug.Havent tried the gas mode yet but is doesn't seem to be getting 110 power.Is there a battery switch somewhere.Oh yes I do have the center bath model.
Thanks so much for your help.
John
30 amp box davidz71 Electrical - Systems, Generators, Batteries & Solar 10 10-23-2005 10:38 AM
Doctor Box Pahaska Our Community 7 11-18-2002 09:53 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 09:45 AM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 04:40 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 11:21 PM
