Old 06-02-2006, 04:40 AM   #15
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Home depote should have the two strand wire I need..
Mrcrowley is offline   Reply With Quote
Old 06-05-2006, 07:41 PM   #16
1976 25' Caravanner
Campton , New Hampshire
Originally Posted by AYRSTRM2
Electric brakes do not have sway control as a feature. There is an emergency maneuver you can take with electric brakes in an EMERGENCY to try to tame sway once it is happening, but the controller or the brakes themselves in no way control sway.
Unless there's some sort of new high tech feedback controller out there that I have not heard of. And can control each wheel separately.
This raises an interesting question . The '76 service manual shows a schematic for electric sway control ( Tru-Track Electric Sway Control ) I have not found this on my coach , possibly was an option . Has anyone come accross one of these ?
ticki2 is offline   Reply With Quote
Old 06-05-2006, 08:50 PM   #17
Images: 59
Ticki2,
There was a brief mention of this a year ago. Here is the thread.
http://www.airforums.com/forum...uch-16549.html
It starts around the middle of the thread. Can you post a scan of the schematic?
markdoane is online now   Reply With Quote
Old 06-06-2006, 03:31 AM   #18
1976 25' Caravanner
Originally Posted by markdoane
Ticki2,
Don't know how well this will work but will give it a try.
Name:	airstream pictures.jpg
Old 06-06-2006, 10:27 PM   #19
Excella CM's Avatar
1978 31' Excella 500
Venice , California
brake/anti-sway
I wonder if anyone has designed or built a computer/sensor controlled differential braking anti-sway? The example in this thread looks like it applies all 4 at once. I wonder if it would work if you could brake the only one side in a hyper-controlled manner?
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-07-2006, 12:40 PM   #20
Loren's Avatar
Electric Brake Anti-Sway Device
My Holiday Rambler, which was manufactured in 1995, had some extra wires that seemed to go nowhere. I found one end of them at the hitch.
When I took it to an RV service tech for some unrelated repairs I asked about the wires. The technician told me that an anti-sway device was available as an option on this trailer, but my trailer didn't have it installed. These wires were for that device.
It was supposed to work by sensing sway and applying brakes on one side to counter the sway. According to the technician, the system didn't work well and was discontinued.
I don't know whether or not his explanation is true, but it's certainly plausible. I had never heard of this system before, and haven't heard of it since.
I would guess that with today's sensors, such a system could be built.
Loren
2012 New Horizons Travel Trailer (formerly an Airstream owner)
2008 Dodge 2500 diesel with Equal-i-zer hitch.
Loren is offline   Reply With Quote
2003 International AS Pahaska 2002 - 2005 International 149 10-01-2017 06:38 PM
Equalizer hitch and sway control Rod Pease Airstream Trailer Forums 15 04-07-2006 11:00 AM
friction vs. dual cam sway Craig Hitches, Couplers & Balls 8 04-29-2003 11:30 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 02:48 PM
