Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 01-21-2007, 05:23 PM   #1
Joe1261
Profile:  1973 31' Sovereign
Union , Kentucky
Where is my Univolt??
I cant seem to find my univolt in my 73 Sovereign!!! ... Can some one please tell me where I can find it, or where it is supposed to be at?
THANK YOU
jOE
Joe1261 is offline   Reply With Quote
Old 01-21-2007, 06:08 PM   #2
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hi Joe -- Where's your battery? The wire run between the battery and Univolt needs to be as short as possible. I'd look within 3-5 feet of the battery. It may be under the gaucho or a cabinet -- often tucked into a very out of the way place. Easiest way to find it? Plug the trailer into a 110v circuit and listen quietly for the hum.
CanoeStream is online now   Reply With Quote
Old 01-21-2007, 06:22 PM   #3
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Joe,
In my 73 Sovereign it is curbside rear, just aft of the battery, and the wardrobe closet. In my limited experience most 70s models have them located somewhere in this neighborhood, but because of the wardrobe it's particularly inaccessable in the Sovereign. Mine has a little sliding access hatch in the bottom of the wardrobe which will let you get at the fuse panel.
Old 01-21-2007, 06:24 PM   #4
Lumatic
Lumatic's Avatar
1962 28' Ambassador
Huuummmm.
Just follow the hum. And if you feel transendental, chant. Huuummmmmmm.
Old 01-22-2007, 08:51 AM   #5
Joe1261
Union , Kentucky
Ok
I found the univolt. I was underneath the bath tub. I havent plugged my trailer in since I brought it back from Florida. ( I am kinda of afraid to right now). There is a closet next to the bath tub and a really small access panel. What I found was a blue box that says "Airstream Univolt" with a small panel that opens up to the fuse panel. Some of the fuses are missling and there are a few wires that just hanging there. but inorder for me to get the univolt out I think I need to remove the aft wall out from the closet. The Univolt is bolted to the floor. I think the battery box is on the curb side back aft, but when I opened it up all I can see is two small holes in the plastic. So I guess I got my work cut out for me. I am not that electricly inclined.
I found the service manual for the trailer but wouldnt you know it the only page missing is the one for the Univolt. The manual is in pretty bad shape. It is falling apart and looks like something has chewed it up. <Sigh> I will let you know once I strat doing some more digging and searching throughout the trailer.
thank you
Joe
Old 01-22-2007, 09:39 AM   #6
Lumatic
Lumatic's Avatar
1962 28' Ambassador
Hi Joe,
More snow in NM this am.
You should be able to get the univolt out without dissassembling the cabinet, although it is tight. there are 4 bolts holding it to the floor. If yu want to test it out I would hook it back up and put a tester on it. Plenty of information on the forum on this. I have had mine limping along for years now, but if I ever take it out I will replace it will an Intellipower unit. I don't want to do the job twice. Plenty of information on this also in the forum archives. If the manual you are refering to is the owners manual, I find the service manual invaluable. They are commonly sold on Ebay. An original is better than a repro for the illustrations but other than that they are comparable. A 73 service manual is best, but most of the information transfers form one year to the next.
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 10:05 AM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 11:08 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 09:26 PM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 05:13 PM
test
