Old 04-01-2019, 01:38 PM   #1
Oxnard , CA
where do I find the OEM installed solar wires?
I have a 2017 25' RB flying cloud
It has OEM installed Zamp solar connections, at the batteries on the A frame and on the roof. A frame is for a portable system with a built in controller, I want to do a roof installation.
There is no controller installed in the trailer and I can't find the pre-installed roof connected wires. Zamp said that they would be in a loop near the electrical / breaker box. In my AS this is under the dinette seat on the front port side.
I want to purchase a controller and panels but I need to find these wires first. Anyone know where to look?
C-cap is offline   Reply With Quote
Old 04-01-2019, 06:35 PM   #2
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
The solar prewires are one green and one yellow wire labeled "solar" that are bundled in with a bunch of wires affectionately know on this forum as the "rats nest". Here is a picture of how I installed my solar controller to the solar prewire on a 2017 FC25FB. You can see the 10 gauge green and yellow wires in the picture, and if you look closely at the floor in the top-right corner picture you can see the "rats nest". http://www.airforums.com/forums/atta...0&d=1539352234 The rats nest was in the front curb-side corner of my Airstream directly below the positive and negative bus bars.
You can see and read about my solar installation, and from many others who showed off their systems in the "Solar Show and Tell" thread: http://www.airforums.com/forums/f448...ll-181608.html
2018 Globetrotter 27Q, 32 nights 4,935 miles, 600W Solar, PD4655L, Duracell EGC2 Batteries, ProPride, 16" Michelin's, Champion 3400W Dual-Fuel, 2019 F250
Sold: 2017 Flying Cloud 25FB, 316 nights 40,150 miles, 400W Solar
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 04-01-2019, 06:41 PM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
The two wire should be under the street side dinette seat.
See photos and blog post
http://www.airforums.com/forums/blog...-install-2959/
http://www.airforums.com/forums/blog...r-photos-2960/
GMFL is online now   Reply With Quote
Old 04-01-2019, 11:14 PM   #4
waninae39's Avatar
2017 22' Sport
NCR , Ontario
The solar prewires are one green and one yellow wire labeled "solar" that are bundled in with a bunch of wires affectionately know on this forum as the "rats nest" under the road side bed corner in a 22fb
waninae39 is offline   Reply With Quote
Old 04-03-2019, 01:47 PM   #5
Oxnard , CA
I'm not looking to install a big solar system. Typically we are hooked up about 50% of the time and have a propane converted 2000 Honda gen. AS has two Lifeline GPL-24T 80 amh batteries and under normal use last 2 or 3 days before needing a charge.
Solar Components I'm considering are:
Victron BlueSolar 75/15 MPPT Charger Controller w/ VE Direct Bluetooth Dongle
2ea Kingsolar Flexible Solar Panels 100 W 18-12 v wired parallel
Anyone install this controller or panels?
Old 04-03-2019, 02:05 PM   #6
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I would avoid the flexible panels they do not last very long.
Factory Installed Solar Charging System SilverGate Generators & Solar Power 507 09-06-2019 11:04 AM
How to remove OEM solar panel mounting brackets? marter Generators & Solar Power 9 10-21-2018 09:59 AM
7 Wires in, but 4 wires to lights..??? KZGoodchild Lights - Interior & Exterior 1 05-03-2017 05:10 PM
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 10:23 AM
