Old 07-13-2017, 11:46 PM   #1
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
What's that smell? Battery edition
Had an interesting experience today that I wanted to share.
Our renovated '79 Airstream Excella has a built in crib for our daughter that she loves.
The crib is directly across from the bathroom.
One day my wife and I started to notice a smell coming from the area near the crib and bathroom. It smelled like maybe there was a dirty diaper nearby or someone had just used the bathroom. We cleaned both the crib and the bathroom but the smell remained. For 2 days we couldn't figure out why it smelled like poop.
The area under the crib houses the batteries and inverter. On a whim I stuck my nose near the exhaust fan of the inverter and low-and-behold smelled the smell! It seemed to be coming from the inverter! At this range, it sort of smelled like sulfur.
I contacted the manufacturer of the inverter to see if this was a known issue with the unit, to which they responded that it certainly could be a failed component in the inverter emitting the smell, but since the inverter seemed to be working fine I should check the batteries.
I took their advice and opened my battery box to find this:
These flooded lead acid batteries had something coming out of the water/cell access holes and boy did it stink like sulfur when I opened the battery box! I had found the culprit.
Upon further inspection I found that the water was low in every single one of the batteries' cells.
I got some distilled water, filled them such that the level in each cell was just above the lead plates, cleaned up the residue, and the smell seems to have dissipated. I guess the gassing from exposed cells was causing the smell?
So the lesson is: if you smell something stinky, it might be your batteries!
trekerboy is offline   Reply With Quote
Sewer Gas Smell davespann Waste Systems, Tanks & Totes 18 07-24-2016 09:57 PM
1997 "American Legend Edition" :: 1997 Airstream American Legend Edition papajer4evr Airstream Registry Discussions 0 01-02-2012 12:54 AM
Boiled out battery smell stowaways Batteries, Univolts, Converters & Inverters 1 07-19-2009 09:34 PM
Bad cabin smell from new Solar instalation w9det 2001 Safari 7 04-21-2003 11:21 AM
Furnace exhaust smell Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-25-2003 08:54 PM
