Old 10-05-2011, 09:20 PM   #1
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
What's That Smell??
We have had a smell in our trailer (2005, 30' Classic) that began about a month ago. I have been unable to find the source... Until yesterday.
I was at work yesterday and called home to talk to my wife at lunch as usual. She said; Oh, by the way, the propane detector in the trailer was beeping this morning, I want in and the smell was terrible, I could only stay for a little while; and Seth (our son) noticed smoke coming out of the front compartment.
Smoke!!??! That sounds serious!
The only front compartment I could think of was the two battery compartments. I asked if this was the compartment. "Maybe." OK, have someone go down to the trailer and unplug the (shore) power from it.
When I got home, I went to the trailer and opened up the battery compartments. The one on the left (port) side was noticeably warm (still). I looked at the battery and it was bulging on the ends. One of the top caps was popped lose too. Well, I think replacing this battery will solve our smell issue too.
I do keep the trailer plugged into shore power when not in use. Is this OK? I suspect that sinced the other battery appears to be OK, that this battery just wore out (they are two different brands), and that the converter/charger is fine. We have only had this trailer since this summer, so we do not know the history.
David
10Smiles is offline   Reply With Quote
Old 10-05-2011, 09:34 PM   #2
cameront120's Avatar
1972 25' Tradewind
Did it smell like rotten eggs? That's propane. If the propane alarm was going off, you could have a gas leak.
North Vancouver, BC
Old 10-05-2011, 09:35 PM   #3
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
when replacing batteries they need to be replaced at the same time and must have the same specs. A battery that is bulging has been over charged/failed.
Michelle TAC MT-0
Sarah, Snowball
Old 10-05-2011, 09:37 PM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
David, it would be a good idea to replace both batteries at the same time with a pair of the same, usually group 27 marine/RV. Having them mismatched, even by age, will seriously shorten the life of both batteries, since they will be "pulling" unequally.
Old 10-05-2011, 10:05 PM   #5
withidl's Avatar
2002 31' Classic
Houston , Texas
Same Thing Happened To Me
Several years ago I walked by my 2002 ASCL 31' and smelled the same acrid odor. One of my batteries was so hot I had to use gloves to remove it.
The problem is the OEM converter isn't smart enough and WILL overcharge the batteries if left on shore power while in storage.
I now use a small motorcycle intelligent charger clipped into the 12 volt breaker panel to keep the batteries topped off when the AS is being stored.
withidl is offline   Reply With Quote
Old 10-05-2011, 10:20 PM   #6
10Smiles's Avatar
2005 30' Classic
It turns out I misunderstood my wife, the alarm was the Carbon Monoxide detector, not the Propane Detector. Yes, it is an "acrid" smell, not propane. Thanks for the responses... Yes, I will replace both batteries. At this point it has just one battery which should be fine for a short while. I need to check the electrolyte level though.
Old 10-05-2011, 10:39 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Batteries can and do fail as a result of a shorted cell. When this happens the remaining cells overcharge. There is nothing the converter can do to detect this.
Old 10-06-2011, 08:43 AM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
IMHO....replace the Para-lax converter, it will ruin any battery plugged in 24/7.
Ruined ours while still on the dealer lot.
It's an easy upgrade in your Classic. Did ours three years ago with no regrets.
ID:	141858   Click image for larger version
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 10-06-2011, 09:44 AM   #9
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Yes, the stock converter will almost certainly "cook to death" any batteries you have in the unit, if you leave it plugged in all the time. If you decided not to upgrade to a better converter, then just don't leave it plugged in. Just plug it in for a day or so before a trip. Then, check the electrolyte level regularly, and DO use batteries of same age, type, charge history and even lot number (if you can get it).
AirsDream is offline   Reply With Quote
Old 10-06-2011, 12:31 PM   #10
87MH's Avatar
1978 31' Sovereign
Images: 292
Another warning thread
This thread should be a serious warning to all who already have or are contemplating installing a battery in the interior of their Airstream.
Without a vapor proof box that is independently vented to the exterior ANY battery (AGM, sealed, gel, or no maintenance can and will off gas, burn, or explode if overcharged.
H2S will kill at as low a level as 100 ppm and deadens the nose recognition (smell) with concentrations as low as 10 ppm. How much warning will you get if the battery fails while you are sleeping?
I walked into a two year old trailer with dogs in it about 2 hours after the owners had last been in it - the H2S concentration was EXTREMELY high (didn't take long after the battery started to boil off).
It truely amazes me that this safety hazard is not taken more seriously.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 10-06-2011, 01:17 PM   #11
webspinner's Avatar
Menlo Park , California
One of the first modifications we made when we got our '71 TradeWind was to build an airtight metal battery box that vented out the bottom (H2S is heavier than air). We did this before we even thought of sleeping in it.
Barbie
Our travel and renovation blog: http://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 10-06-2011, 01:42 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
One thing you can do is put either the airstream or the converter on a timer. just have it on for an hour a day.
I have been stubborn and am using the original converter. After this and other posts I am considering changing.
Old 10-06-2011, 03:56 PM   #13
The one I used is on sale now...great deal!!!
Amanamus
"Tahawus"
Old 10-06-2011, 09:10 PM   #14
10Smiles's Avatar
2005 30' Classic
It turns out the "smoke" was actually steam. It's interesting how things get turned around. It was raining that day and some water must have gotten into the battery compartment. I am actually glad this happemed since it pointed me in the right direction to find the bad battery as well as eliminate the source for the odor.
I may just have to invest into a new converter/charger. The one that Robert has a link to above is tempting.
David
Bee Hives under belly pans - is that the smell? godaddy64 General Repair Forum 0 09-29-2011 05:44 PM
I smell burning wires! crazeevw Classic Motorhomes 32 09-26-2011 09:13 PM
Oohh that smell..Melting plastic? ArgosyGypsy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-16-2011 12:08 PM
What's that smell? zedex Waste Systems, Tanks & Totes 55 02-28-2011 12:54 AM
I Don't want that smell to go away!!!! THEPILL 2006 - 2010 International 12 12-30-2010 08:39 PM
