Old 04-17-2010, 08:49 PM   #1
Cutten , California
what's going on here?
When our 08 27ft Classic is connected to an AC power source the electricty goes on and off intermittently. There is a "clunk" sound in the electrical panel when the juice goes off and the same noise when it comes back on. The noise is similar to a contacter for a large electric motor. Yes, it restores itself.
The breakers (Cutler Hammer), seem to be alright, snap on and off without being slushy and I replaced the GFCI. The problem is worse when the AC load is increased. Any ideas?
seacur50 is offline   Reply With Quote
Old 04-17-2010, 08:57 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Do you have an inverter? Some inverters have a transfer switch that could be what you are hearing.
All power or just some outlets stop working?
Garry
Old 04-17-2010, 09:09 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
Are you connected to a dedicated 30 amp outlet? If you are connected to a standard 15 amp household outlet, you might be overloading the system causing it to react that way.
Brian
SuEllyn & Brian McCabe
Old 04-18-2010, 10:13 AM   #4
CountryBob's Avatar
2012 25' Flying Cloud
Manasquan , New Jersey
Do you have a power monitor installed? It is installed prior to circuit breakers and will shutdown input current if certain requirements are not met like minimum voltage, bad ground etc....
CountryBob is offline   Reply With Quote
Old 04-18-2010, 12:46 PM   #5
Cutten , California
No inverter Garry. The power failure seems to be complete when it occurs. Everything is working fine this morning (20A garage circuit). I'll hook up to the 2000i Companion when I'm back from fishing this PM. Should replicate the prob. The system pops off everytime the 30A outlet from the generator is used after about 3 minutes. Paralleled to a second 2000i same thing. Puzzleing.
Old 04-18-2010, 12:58 PM   #6
Cutten , California
20A from my garage Brian. The breaker at the garage subpanel does not trip. I am aware this source is underrated for the airconditioner/heat pump. It should run the other systems without any difficulties, it's working right now. The problem is at it's worst when I go to Honda power.--------Will post progress rpts. Tx Sea
Old 04-18-2010, 01:09 PM   #7
Cutten , California
I was not aware of such an animal Sir, but it meets all the criteria for prime suspect. I'll check it out this week. ------------Thanks
Old 04-18-2010, 08:08 PM   #8
garry's Avatar
1969 31' Sovereign
I was going to suggest other things (frig or freezer) on the garage circuit may be a problem but you say it happens on generator power also.
That makes it sound as if the problem has to be in the AS so I would pull the breaker panel cover and make sure ALL screws on the main, neutral and ground are good and tight. If that checks out I would suspect the shore power cord.
Garry
Old 04-19-2010, 09:49 AM   #9
Cutten , California
Just finished tightening all terminations and the coverup plate removal inspection reveals disappointing findings. 1. The previous owner or unknown 3rd party has tighted the connections with an illfitting screwdriver 2. All terminations were tight 3. The vertical grounding bussbar on the lefthand side has been hot enough to melt point of contact on the plastic insulator that it is mounted on 4. The white insulation on some of the ground leads to the bussbar has been discolored from heat
The damage had to be prior to my owning this unit. I would think this would have had to produce smoke and excitement inside the trailer and we have not seen anything like that. Time to visit a pro and get this fixed. We're planning to tow the AS to Alaska next month and this won't cut it.
Thanks Garry and all. Will let you know what the culprit was when repairs are made. Sea
Old 04-19-2010, 12:48 PM   #10
richinny's Avatar
2011 34' Classic
has this trailer ever been under water?
Ricky
Old 04-19-2010, 07:29 PM   #11
garry's Avatar
1969 31' Sovereign
Sounds like it might have been plug into a 220 circuit sometime in the past.
You may need a new breaker panel.
Most electricians are very good at what they do but I have seen situations where the ground and neutral wires were bonded the same as in your house this is a no no for any camper.
The ground and neutral wires "must" be on separate bars.
Garry
Old 04-19-2010, 07:30 PM   #12
Cutten , California
Nothing to indicate that. Near showroom condition.
Old 04-20-2010, 05:51 AM   #13
Cutten , California
Ground and neutral are on seprate buss bars. Wireing was done in a workmanlike manner. Very clean job.
I've got an appt. with the dealer in OR next week. That's the nearest Airstream tech support for us.
Thanks, Sea
Old 04-20-2010, 08:17 AM   #14
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Are the connections at the bus bar tight? A loose connection there would explain heat and a fluky system.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
