Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-24-2006, 09:02 AM   #1
Steve Heywood
Steve Heywood's Avatar
Profile:  1997 30' Excella
Ferndale , Washington
What's The Best Replacement Converter.
The converter in my Excella "acts" like it's charging my batteries but it's not.
What's the best replacement converter presently on the market?
Steve Heywood
Ferndale, WA
2005 Ford F250 CC Powerstroke
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 06-24-2006, 09:13 AM   #2
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Steve,
I'm probably going to go with an intellipower 9200 series for the Ambassador. They have the charge wizard built in that helps prevent over charging.
I think the guy at bestconverters.com used to offer discounts to forum members.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Safari Tim is online now   Reply With Quote
Old 06-24-2006, 09:26 AM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
I don't think they carry the 9200 series and BTW it is http://www.bestconverter.com
I have seen the 9200 series at VTS http://www.vintagetrailersupply.com/
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 06-24-2006, 09:33 AM   #4
Darol Ingalls
Darol Ingalls's Avatar
Profile:
Steve, I agree with Tim. I've used Intellipower units on several trailers with great success. One caution: decide what style of battery you're going to stick with, either lead/acid or gell cell/AGM because the charge Wizard is calibrated differently for each style. Ask the distributor when you buy the unit if they don't ask you. If you buy directly from Intellipower, they will ask what type of battery you have, so there must be some small difference in the way the Wizard works on each battery. Darol
Darol Ingalls is offline   Reply With Quote
Old 06-24-2006, 09:55 AM   #5
Steve Heywood
Intellipower, which one??
OK, you've convinced me. Any guess as to which model I need? I plan to stick with conventional lead-acid batteries and since I plan to add a 3rd will have 3 group 27 batteries total.
Steve Heywood
Ferndale, WA
Old 06-24-2006, 10:44 AM   #6
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Get whichever one has the lead acid charge wizard, and at least 60A output.
A coach of your size, and 3 batteries will need that as a minimum.
I have the 60A in my 63, and with all it's lights and extras, it works well. I run 2 lead acid batteries, which the Intellipower does a great job of keeping charged. The unit is also very small and light.
Uwe
Old 06-24-2006, 06:56 PM   #7
Melody Ranch
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1947 22' Liner
Valley View , Texas
Images: 18
9200??
This is very interesting. The Bestconverter folks told me, last month, that they were NOT recommending the 9200 because of too many recall problems. I went with WEFCO to avoid the problem and have a full function converter.
Old 06-24-2006, 07:41 PM   #8
T Man
7751
T Man's Avatar
Huntington Beach , California
Do check Best Converter
I was going to buy a intellipower with the charge wizard but I picked up a WFCO unit after talking to Randy at bestconverter
The reason is there some thought that AGM batteries should not be charged in the same way that lead acids. (I am going with the AGM type batteries soon)
In any case I found the people at best converter very nice and I would buy from them again.
-T
T Man is offline   Reply With Quote
Old 06-29-2006, 06:04 PM   #9
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
I want to make sure my comments didn't get taken out of context. I do not know of any recall on the 9200 series and would not have suggested that. I was and am however concerned about the number of reconditioned units available so early on in the production cycle. I'm pretty sure that was my comment. Please do not think I feel the 9200 won't give you good service, I have no reason to believe that other then what I said about the reconditioned units already available.
Having said that, I'm still not ready to carry them but I do have one that I am testing.
I do have confidence in the PD9100 series, all WFCO units, and believe it or not, the Parallax for those that only need single or two step charging.
Thanks guys.
Old 06-30-2006, 09:46 AM   #10
uwe
418
uwe's Avatar
Images: 40
Reconditioned....
...often means reboxed, or re-distributed. Certain models might have been delivered as a bulk order to a RV mfg, and then returned etc.etc., reboxed and sold as "reconditioned" since it woul be ethically wrong to sell them as new. So, the term "reconditioned" or "refurbished" often has nothing to do with the actual product, but rather with distribution, repackaging, or marketing.
Uwe
Old 06-30-2006, 04:36 PM   #11
68 Overlander
Commercial Vendor
Images: 21
Good point Uwe. Might be the case but they cut the warranty in half so who really knows.
Water heater replacement Craig Water Heaters, Filters & Pumps 35 06-18-2007 07:47 AM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 07:52 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 09:45 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 01:08 PM
Converter box for into floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 10:49 PM
test
