Old 06-18-2006, 03:44 PM   #1
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Question What was behind this door?
I just bought a 1976 AS Sovereign 31ft from an RV dealer near Toledo, OH. And after getting new tires all around and a wheel bearing re-pack, I safely towed it 700 miles home. It's in GREAT condition and I am pleased with my purchase. Now, I'm in the exploratory phase, looking in all the drawers, cabinets, every nook and cranny, ect., examining everything in detail to familiarize myself with exactly what I have. When I asked the dealer about the DC Converter during my "check out" phase, he said that they had replaced it with a new one. I asked where it was, I wanted to see it. He said it was under and in back of the stove, not a place you could "see" the Converter. A few minutes later, I got down on my knees and pulled the door open and looked under the stove and I could see the water pump, but no Converter. I could see that there was some positive charge current going into the battery (the trailer was plugged into 117VAC) by looking at the ampmeter on the control panel. So, I concluded there must be a DC Converter back there somewhere. When I got home and was poking and looking, I discovered the little sliding door, just to the left of the entrance door. I opened it and there was a DC fuse board with several connections....and a fairly large space/platform behind the stove where something used to be. That "something" is now missing! Clearly there was somthing in there....my question is "what was it"?
Then I plug the trailer into the house current and put my voltmeter directly across the battery terminals and there was 13.6 volts there, indicating it was receiving a charge from somewhere. The voltage dropped to 12.5 volts when I removed the house current, further confirming the presence of a charger. Now, I'm wondering how I can further prove to myself that there is a Converter behind the stove without having to remove the stove to "see" it!!
Any ideas? And.....what was in that empty space behind the stove? Thanks, Bill
lebolewis is offline   Reply With Quote
Old 06-18-2006, 04:05 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Hi Bill ~
Congrats on your purchase. Sounds like you're having a great time exploring and getting to know your Sovereign. Try using a small hand held mirror back there if you can get your arm extended behind the edge of the oven. Just a thought.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 06-18-2006, 04:30 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Someone probably replaced the (huge) old Univolt, and replaced it with an Intellipower, or other converter, which is about 1/4 the size, and 1/10 the weight. It could be nestled in behind something, and not be readily visible.
Old 06-18-2006, 05:07 PM   #4
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Talking Calling all Newbies
This is a comment for the Newbies out there. You just have no idea how much stuff there is to see behind drawers, in crevices, in storage compartments, under, over and between the major appliances and the operating systems in an Airstream! If you are the curious type, it will take you hours to "see" and check out everything!! ......but it's a "fun" thing!! Chief Inspector, Bill
Old 06-18-2006, 06:21 PM   #5
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Bill,
If your 76 is like my 79 with the oven just to the left of the entrance, there's a space to store folded lawnchains there, right behind the oven.
It's a safe bet that your converter is not very far from the fuse panel. With the old ones, all you have to do is to follow the HUM.
It's a good idea to get the owner's manual and carry one or two spare fuses for every circuit in the trailer. A short in the two vehichle can blow fuses in the trailer. (Ask me how I know.)
Also, if you're lucky, the dealer will have stashed the instructions for the power converter somewhere in the trailer. (My PO had put everything back to the mid 80's in a drawer in the galley.)
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Door Catches niftypkg Doors & Locks 4 05-22-2007 05:09 PM
1965 Main Door buckmaster 1965 - 1969 Globetrotter 0 10-19-2002 07:47 PM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 05:53 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
