Old 04-17-2011, 01:07 PM   #1
AlumiLust
Plano , Texas
What type of outlet boxes for 120 volt?
I ran all new wiring in our 79 Sovereign and now I'm at a point where I'm adding, outlets on the 120 volt circuits. The walls in the Airstream are not as deep as residential walls so I'm having difficulties finding a box that is deep enough to hold the wiring, the outlet AND fit in the limited depth between the inner and outer skins. What are other folks using out there?
bgolden is offline   Reply With Quote
Old 04-17-2011, 01:15 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
There is a shallow box, blue in color. I purchased them at HD.
Bill
Just my personal opinion
Old 04-17-2011, 08:41 PM   #3
KYAirstream's Avatar
Northeastern , Kentucky
Just curious...what prompted you to run new 110 in your 79?
KYAirstream is offline   Reply With Quote
Old 04-17-2011, 08:54 PM   #4
What's a rivet?
SilverBreeze's Avatar
2008 23' International CCD
Napa , California
You will need shallow single gang boxes, you can find them in either plastic or steel. Home Depot or Lowe's may have them otherwise and electrical supply house can get them for you. Good luck.
SilverBreeze is offline   Reply With Quote
Old 04-18-2011, 05:16 AM   #5
AlumiLust
Plano , Texas
What type of oulet boxes for 120 volt?
Thanks for responses. I'll keep 'a looking. We bought the AS used and it needed serious electrical work, had some water damage so I ultimately decided to gut it last fall.
Here is a photo of some of the wiring on our blog. We ultimately tore it down to the frame [shell on], and are rebuilding it from the ground up - including new Dexter axles. The blog is recording our work. Our last name is Golden and are planning to do a Mexican architecturally-influenced interior so we named her 'Casita del Oro'.
Old 04-18-2011, 07:02 AM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Vintage trailer sells these:
Shallow Phenolic Outlet Box
They are a tad pricey, but they do have the advantage of being a tad larger than the shallow blue boxes you can buy at Home Depot, Menard's, or Lowe's. I'm using the blue boxes if there is only one 110 VAC wire in the box with the outlet at the end of a circuit run, and using these from Vintage where I have 2 wires (1 in and 1 out to feed downstream outlets). They are as close to the original box size as I've been able to find.
Chris
Old 04-18-2011, 11:54 AM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Current production trailers use a special outlet that doesn't require an outlet box. You could try those.
Old 04-18-2011, 01:08 PM   #8
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
This is what I used. Shop Wiremold 2-Gang Plastic Duplex Electrical Box at Lowes.com
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 04-19-2011, 09:42 AM   #9
AlumiLust
Plano , Texas
Thanks again all. Chris - thanks for the tip on VTS. Just ordered a few of those boxes.
12 volt
120 volt outlets from battery power? etobolski Electrical - Systems, Generators, Batteries & Solar 4 04-05-2011 02:15 PM
What type of water heater do I need? doglickfarms Water Heaters, Filters & Pumps 12 03-28-2011 10:36 AM
Exterior Aluminum type for an 1988 Excella? Rob&Julie Ribs, Skins & Rivets 0 02-14-2011 08:04 AM
Exterior outlet on '04 Safari DJW Electrical - Systems, Generators, Batteries & Solar 6 01-23-2011 07:17 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
