Old 11-25-2002, 09:25 PM   #1
Anna's Avatar
Question What type of battery should we get?
What type of battery should we get for our 1974 Overlander? Gel Cel?
Anna
Anna is offline   Reply With Quote
Old 11-26-2002, 04:56 AM   #2
LOST , Hawaii
Try this link it has a lot of really good info on batteries. Gel cell are expensive, but if you use battery power a lot they are worth it. I am not sure gel cells and a univolt would be a good combination so that would be another expense to consider.
John
74Argosy24MH is offline   Reply With Quote
Old 11-26-2002, 10:03 AM   #3
Obsessed with Moonunit
COArgosy78's Avatar
1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 55
Lightbulb Another thread with info
There is another thread called "Great Tech Info" here (if you go to the search button and type that in, it should take you there). It has some links and good info on batteries. I was trying to figure out how to link it to this thread, but have to admit defeat so far!
One site that I put on to that thread has a 2 part fact filled report on batteries. Good Hunting. Leigh
COArgosy78 is offline   Reply With Quote
Old 11-26-2002, 10:23 AM   #4
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Trojan Batteries has a Group 27 12 volt, 115AH battery which if used in a parallel pair, has a bit more capacity than two of their taller, but smaller base, 6V T-105s in series.
That's what I'd go for if it'll fit in your battery compartment(s). It's very slightly taller than most other Group 27 batteries.
Maurice
Maintaining your Batteries joshua32064 Batteries, Univolts, Converters & Inverters 17 04-29-2008 10:03 PM
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
