Old 05-17-2015, 08:40 PM   #1
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
What Things Use Power in Amps
Today I did a little experimenting. I plugged in my Kill-A-Watt, a device that measures electricity into the main 30A cord going into the trailer. Here's what I learned.
  • 0.30 Amps - Minimum draw with everything off. Mostly the power converter. This load factors into everything measured below.
  • 0.50 Amps - Radio on.
  • 3.10 Amps - Refrigerator on electric.
  • 0.50 Amps - Refrigerator on propane.
  • 11.9 Amps - Water heater on electricity.
  • 0.50 Amps - Water heater on propane.
  • 2.70 Amps - AC (fan only)
  • 14.0 Amps - 15,000 BTU AC on full blast.
  • 17.6 Amps - Momentary peak when AC starts.
Voltage was at 121.4 volts for all tests except when the AC kicked in the voltage dropped to 118 volts.
kscherzi is offline   Reply With Quote
Old 05-17-2015, 08:53 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup.... Pretty close on our 34' with heat pump loads. Thanks for taking time to do this!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-17-2015, 10:14 PM   #3
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Its always nice to know what's really going on. Thanks for taking the time to share this.
NavyCorpsman is offline   Reply With Quote
Old 05-18-2015, 05:15 AM   #4
Gainesville , Florida
Gonna copy that for future reference. Thanks,Jim
Old 05-18-2015, 10:23 AM   #5
1977 31' Sovereign
Lynnwood , Washington
This is ALWAYS good stuff to know.
Thanx for sharing that.
Tom
TomKirk is offline   Reply With Quote
Old 05-18-2015, 10:49 AM   #6
1968 20' Globetrotter
Avondale , Arizona
Watt about your water pump? (electrical pun, please excuse) ...or are you always hooked up to pressurized water?
joyful2 is offline   Reply With Quote
Old 05-18-2015, 11:04 AM   #7
2012 30' Classic
Homosassa , Florida
Very good information. Thank you for taking the time to gather this information.
Tater is offline   Reply With Quote
Old 05-18-2015, 11:38 AM   #8
kscherzi's Avatar
Images: 24
I forgot about the water pump, but I'd have to fill the tank and it was getting late. I can check it later.
Part of the reason for doing this is to figure out if the Yamaha EF2400iSHC generator would work for the AC. According to their spec it puts out 16.5 amps continuous. So in theory it would work, but barely, only because the fridge and water heater would also most likely be running (on propane). I'm confident the two Honda's would work, but prefer a simpler solution (if it would work).
Old 05-18-2015, 12:00 PM   #9
This thread from ten years ago gives amp consumption for my 1988 Excella: http://www.airforums.com/forums/f37/...ter-15625.html
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 05-18-2015, 01:21 PM   #10
2000 30' Excella
2014 30' Classic
Princeton , Iowa
Thanks, really good to know.
larryglarson is offline   Reply With Quote
Old 05-18-2015, 01:36 PM   #11
2013 16' Sport
Boulder , Colorado
Thank you! My reply to this thread also serves to bookmark it!
Seecue is offline   Reply With Quote
Old 05-18-2015, 03:09 PM   #12
Wayzata , Minnesota
I found this a few months ago on Do It Yourself RV --
120 Volt AC RV Appliances And Their Estimated Current Draw
WendyW.
"I would feel more optimistic about a bright future for man if he spent less time proving that he can outwit Nature and more time tasting her sweetness and respecting her seniority." (E.B. White)
WendyW. is offline   Reply With Quote
Old 05-18-2015, 03:19 PM   #13
Tincampers's Avatar
Sneedville , Tennessee
I have the Yamaha 2400iSHC generator and it will run the AC. I did not try to run anything else though.
Tincampers is online now   Reply With Quote
Old 05-18-2015, 03:31 PM   #14
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Thanks for doing this. I found a simpler solution was to sell the two Honda EU2000's and but a Honda EU3000iHandi. Used it all last summer and worked great.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
30 amps vs 50 amps @ Rv parks ColoradoLady Electrical - Systems, Generators, Batteries & Solar 18 07-25-2015 07:59 AM
Going from 50 amps to 30 amps for a 23FB KWN306 Electrical - Systems, Generators, Batteries & Solar 1 01-28-2015 11:12 AM
Airstream - How Can You Get Some Things so Right....and Other Things so..... Fly at Night Our Community 19 12-08-2013 07:44 PM
15 Amps vs 30 Amps billida1 Electrical - Systems, Generators, Batteries & Solar 8 10-01-2010 08:37 AM
Meter for amps davidz71 Electrical - Systems, Generators, Batteries & Solar 5 05-09-2002 10:21 AM
