05-17-2015, 08:40 PM
2013 27' FB International
El Dorado Hills
What Things Use Power in Amps
Today I did a little experimenting. I plugged in my Kill-A-Watt, a device that measures electricity into the main 30A cord going into the trailer. Here's what I learned.
- 0.30 Amps - Minimum draw with everything off. Mostly the power converter. This load factors into everything measured below.
- 0.50 Amps - Radio on.
- 3.10 Amps - Refrigerator on electric.
- 0.50 Amps - Refrigerator on propane.
- 11.9 Amps - Water heater on electricity.
- 0.50 Amps - Water heater on propane.
- 2.70 Amps - AC (fan only)
- 14.0 Amps - 15,000 BTU AC on full blast.
- 17.6 Amps - Momentary peak when AC starts.
Voltage was at 121.4 volts for all tests except when the AC kicked in the voltage dropped to 118 volts.
05-17-2015, 08:53 PM
1999 34' Excella
Hillsboro
Yup.... Pretty close on our 34' with heat pump loads. Thanks for taking time to do this!!
Peace and Blessings..
Channing
WBCCI# 30676
05-17-2015, 10:14 PM
Regular Guy
1978 31' Sovereign
Hot Springs
, Arkansas
Its always nice to know what's really going on. Thanks for taking the time to share this.
05-18-2015, 05:15 AM
Mantua
, Ohio
Gonna copy that for future reference. Thanks,Jim
05-18-2015, 10:23 AM
1977 31' Sovereign
Lynnwood
This is ALWAYS good stuff to know.
Thanx for sharing that.
Tom
05-18-2015, 10:49 AM
1968 20' Globetrotter
Avondale
Watt about your water pump? (electrical pun, please excuse) ...or are you always hooked up to pressurized water?
05-18-2015, 11:04 AM
2022 Atlas
Homosassa
Very good information. Thank you for taking the time to gather this information.
05-18-2015, 11:38 AM
El Dorado Hills
I forgot about the water pump, but I'd have to fill the tank and it was getting late. I can check it later.
Part of the reason for doing this is to figure out if the Yamaha EF2400iSHC generator would work for the AC. According to their spec it puts out 16.5 amps continuous. So in theory it would work, but barely, only because the fridge and water heater would also most likely be running (on propane). I'm confident the two Honda's would work, but prefer a simpler solution (if it would work).
05-18-2015, 12:00 PM
This thread from ten years ago gives amp consumption for my 1988 Excella: http://www.airforums.com/forums/f37/...ter-15625.html
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
05-18-2015, 01:21 PM
2000 30' Excella
2014 30' Classic
Princeton
, Iowa
Thanks, really good to know.
05-18-2015, 01:36 PM
2013 16' Sport
Boulder
Thank you! My reply to this thread also serves to bookmark it!
05-18-2015, 03:09 PM
Wayzata
WendyW.
"I would feel more optimistic about a bright future for man if he spent less time proving that he can outwit Nature and more time tasting her sweetness and respecting her seniority." (E.B. White)
05-18-2015, 03:19 PM
Sneedville
, Tennessee
I have the Yamaha 2400iSHC generator and it will run the AC. I did not try to run anything else though.
05-18-2015, 03:31 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
Thanks for doing this. I found a simpler solution was to sell the two Honda EU2000's and but a Honda EU3000iHandi. Used it all last summer and worked great.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
05-18-2015, 09:23 PM
1979 23' Safari
Wayland
, New York
Thanks, good info, I was wondering if I'd need to upgrade my 30A to 50A (knowing it'd be close) with the addition of an electric/propane fridge, but it looks like as long as the AC, water heater, fridge, and microwave aren't running at the same time I shouldn't have to worry. Just need to make sure I only keep the electric element in the water heater on only when i'll actually be using lots of water, eg.showers.
05-18-2015, 11:19 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Our experience as well ...and you have to enjoy that electric start on the 3000iS.
05-19-2015, 08:10 AM
2015 30' Classic
Sherwood
, Oregon
Thanks for taking the time and sharing.
05-19-2015, 11:49 AM
2008 16' Safari
Portland
, Oregon
My water pump draws 7 amps (12 volts)
05-20-2015, 06:21 AM
1995 30' Excella
Bowie
, Maryland
I'd recommend measuring the 12 volt devices directly, rather than through the converter.
Or, at least, realize that what the 12 volt devices draw via the converter isn't going to be the same as what it draws from only the battery, because the converter isn't 100% efficient.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
