Old 01-27-2011, 12:37 PM   #1
Bermshot's Avatar
1971 31' Sovereign
Dallas , Texas
Images: 32
What the heck is this wire?
I've gutted a 71 sovereign and have found what seems to be 2 fiber optic wires coming in by the 110 box above the water heater opening. They were putting out a red light but I had no power hooked up. Later after cleaning up various shorts I did hook up a battery to test the 12V system and waited until dark to see how well the lights actually did. I noticed the 2 wires no longer had the red glow.
I found a small 1 inch plastic part mounted on the outside above and forward of the H2O heater door that has 2 small red lens facing towards the front of the trailer, shined the flashlight into them and the open ends lighted up again! I'm guessing now that this was conected in front of the pilot light and you could view it from the front of the trailer or even from the TV if it was bright enough. Am I off track, has anyone seen this set up and is it standard equipment?
Bermshot is offline   Reply With Quote
Old 01-27-2011, 12:50 PM   #2
x
XXXX , XXXX
Those fiber optic cables are part of the taillight monitor system in the trailer. The other ends of the cables are supposed to be mounted one in each taillight. You are right in that from the TV you can "monitor" your taillights and turn signals to see if they are still operating. It is not connected to the water heater or the pilot light.
wasagachris is offline   Reply With Quote
Old 01-27-2011, 03:32 PM   #3
1995 25' Excella
waynesboro , Virginia
I had the same question some time ago, did some research and believe the answer given by wasagachris to be correct.
waltero is offline   Reply With Quote
Old 01-27-2011, 05:53 PM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Yes, WC is correct. Our 72 has them as well. They run from the inside of each tail light housing, in between the inner and outer skins to the little holder on the side of the trailer. One fiber optic for each tail light.
Chris (MC)
Old 01-27-2011, 09:34 PM   #5
Ottawa , ON
Of course, my '74 has them too, and I've always thought that they were the most clever thing that AS ever put on their trailers.
Imagine that: fibre optics, in the early '70s, standard equipment! No wonder we love these wonderful devices...
fiber optic, taillights
Questions on wiring brakes and lights the544man Brakes & Brake Controllers 7 02-14-2011 08:20 PM
Please help identify this wire chingon Electrical - Systems, Generators, Batteries & Solar 22 01-31-2011 08:42 AM
'89 Excella, Mystery wire bundle, hitch area, photos cjack99 1987 - 1989 Excella 3 01-27-2011 05:03 PM
'67 Caravel Restoration Electrical question vonzellen 1966-68 Caravel 1 01-15-2011 08:25 AM
Landscape Wire Brianv512 Electrical - Systems, Generators, Batteries & Solar 13 01-06-2011 11:00 PM
