Old 11-09-2011, 10:08 AM   #1
2009 34' Panamerica
Los Angeles , California
What size generator?
Hello all,
I am getting ready to take a 34 Pan America to NYC for six weeks and am wondering what size generator I will need in order to power the trailer and run 3 small ceramic heaters as well as three barn lights that go in a 25ft military tent that attaches to the end of the trailer. I have been looking at a 5000 watt Honda. Any suggestions would be greatly appreciated.
Best,
matt
Aether is offline   Reply With Quote
Old 11-09-2011, 10:13 AM   #2
dznf0g's Avatar
Oswego , Illinois
HOw many watts are the heaters each? how many watts are the barn lights each? Will you be powering the AS by gennie as well?
-Rich-
Old 11-09-2011, 10:24 AM   #3
SteveH's Avatar
Common Sense , Texas
Those heaters are normally 1500 watts, so that's 4500 not considering the other drains. I would say 5000 would be cutting it too close.
Regards,
Steve
Old 11-09-2011, 11:20 AM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Electric heat will be expensive - about 10 to 15% of the generator fuel will actually wind up as heat in your conditioned area.
If you must go electric heat I'd skip the ceramic heaters, they are hot spots that heat the ceiling from large temperature differences and the heat rising - look at Vornado brand heaters, they are a strong fan that adds a little heat to a lot of air; real cold draft killers!
I just kept a 10x20 tarp shelter at or above 60F with one heater even with overnight lows in the upper 20's to make sure the floor paints cured as I finish my shell-off rehab (and that was with a 200'-plus wire run).
The ones I have were end-of-season clearance but we just saw them at Costco for $38 each. The heat comes out at a safe temperature too in case someone lays their jacket too close to it too, etc..
Old 11-09-2011, 11:28 AM   #5
SteveH's Avatar
Yes, the electric heaters are not very efficient, and after thinking about it, I believe I would plan to use the Airstream's propane furnace, and in doing so, you could easily get by with one of the 2KW generators. You would, however use quite a bit of propane.
Regards,
Steve
Old 11-09-2011, 12:25 PM   #6
2009 34' Panamerica
The heaters are 1500 watts each so I would definitely be cutting it too close I think. I might have to switch to a 5000watt and a 3000. We want people to be real warm. The propane heater is not an option bc we have gutted the Airstream and built a log cabin inside.
Thanks all of you for your quick responses.
Old 11-09-2011, 12:27 PM   #7
F450Harley's Avatar
2006 30' Classic
Yonkers , New York
Images: 44
Your 5000 or Honda EU 6500 ISA is plenty power to keep you warm. Try the small WORKFORCE heaters from home depot at ($25) or so. The most important consideration is the site location with regards to generator noise (decibel) tolerance. Check to make sure that you will be allowed to use a regular noisy generator especially at night. The honda EU series (3500 0r 6500) are quiet and NYC residents might overlook the 56 decibel noise from any of these units. I have two of the workforce heaters in my 31' 2006 classic but only use one combined with the AS propane furnace in extreem cold weather. If you are coming to NYC in the next two months (Nov - Dec), let me know and I can help you with refill of your propane tanks as needed 'cause you definetly need it. Enjoy your trip.
F450Harley is offline   Reply With Quote
Old 11-09-2011, 12:30 PM   #8
F450Harley's Avatar
2006 30' Classic
Yonkers , New York
Images: 44
Just read your last post so disregard my propane furnace ranting ....................
Old 11-09-2011, 12:39 PM   #9
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Can you post pictures of your fancy log cabin Airstream??
10Smiles is offline   Reply With Quote
Old 11-09-2011, 01:09 PM   #10
1981 31' Excella II
New Market , Alabama
You can get portable propane heaters for heating your exterior tent.
Perry
Old 11-09-2011, 01:29 PM   #11
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Perry
18000 btu/h "Big Buddy" propane heater that looks like it burns a bit less than 1 lb of propane per hour on the high setting is $149 each at Wal-Mart.
You could buy a lot of those for the price of a Honda 5kw generator.
David
Old 11-09-2011, 03:52 PM   #12
1974 Argosy 20
Kooskia , Idaho
Too dangerous inside an AS. Use the built in propane furnace.
Old 11-09-2011, 05:14 PM   #13
DKB_SATX's Avatar
1976 Argosy 28
He doesn't have the furnace installed anymore, and needs to heat a big tent space. In NYC in winter.
David
Old 11-09-2011, 05:25 PM   #14
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I suspect debate about the safety of the Big Buddy can go on and on, but let me ask 2 questions:
1. Has anyone who has used one of these an opinion on using them in a AS?
2. Has anyone any direct experience to base the opionion they are unsafe?
The key word in the product description seems to me to be "ventilation". Is the Big Buddy a catalytic heater of does it have a flame?
Generator won't start! Lily&Me Generators & Solar Power 14 09-11-2012 05:23 AM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
