Old 11-09-2011, 05:43 PM   #15
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
It's described as an "indoor/outdoor heater" and it states that it requires ventilation, and has an oxygen sensor that will shut it off. Surely they'd specify if it's a catalytic heater, and charge 3x as much.
My (perhaps unfounded) assumption is that this is not for camping in but for some display purpose, since they have "gutted the Airstream and built a log cabin inside." I would certainly agree that this isn't a good choice for heating sleeping space or even a space that's going to be closed up tightly. I should have stated my assumptions earlier but was reading/posting during a work break.
— David
Old 11-09-2011, 06:38 PM   #16
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Depending on your end use there is quite a range of propane heater products you can research:
Propane heaters available at the heater shop
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 11-10-2011, 10:36 AM   #17
2009 34' Panamerica
Los Angeles , California
Thanks for all or the responses. I tried to post pictures but I think the moderators thought that I was posting commercial links. Anyways you can see it in the blog section if you search for Aether Apparel. I hope that is ok, Im not promoting anything. I think we are going to go with a 3000watt and a 5000watt.
Best,
matt
Aether is offline   Reply With Quote
Old 11-10-2011, 11:12 AM   #18
Generator capacity.
To determine "what size" generator, is a matter of simple arithmatic.
Add up the total at one time maximum wattage needed.
Add 25 percent to that number.
Never, ever, use a generator to more than 80 percent of it's output. To do so, will shorten it's life.
Old 11-10-2011, 06:05 PM   #19
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Electric heaters are as close to 100% efficient as anything can be. There is no exhaust from an electric heater therefore all of the heat it produces is within the space it is used. Whereby a propane furnace like the original is not as efficient, 60 to 85% efficient at best. Any heater that requires an external exhaust will not be close to 100% efficient. Those that don't require an exhaust could be a health hazard. We recently returned from a trip across Nebraska to north central Iowa where night time temps were in the low 20's. We used 2 1500 watt ceramic heaters in our 26'Argosy, both units were set on the low setting (1200 watts). Never felt the slightest chill.
Old 11-10-2011, 06:11 PM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Generators on the other hand are not very efficient when you consider the BTU value of the fuel as compared to the actual BTU value of the output of the generator. The engine of the genset is at best 85% efficient, add that to the efficiency of the generator (alternator) which is also about 85% efficient and you are looking at 70% efficiency at best. Input BTU to output BTU.
Old 11-10-2011, 07:28 PM   #21
F450Harley's Avatar
2006 30' Classic
Yonkers , New York
Images: 44
Best,
matt
Aether,
I think this is the link : Aether Apparel Airstream | Selectism.com
F450Harley is offline   Reply With Quote
Old 11-11-2011, 09:43 AM   #22
2009 34' Panamerica
Thats us. Im off to NYC. We ended getting a 6500watt generator.
Best,
matt
Old 11-11-2011, 10:02 AM   #23
timmaah's Avatar
1999 25' Safari
On , the road
Originally Posted by F450Harley View Post
Aether,
Few more pics here:
Aether – Blog | Airstream
He didn't even mention the hanging fireplace..
Nice job.
timmaah is offline   Reply With Quote
Old 11-11-2011, 05:35 PM   #24
F450Harley's Avatar
2006 30' Classic
Yonkers , New York
Images: 44
Best,
matt
Let me know your arrival time & exhibition site and I might stop by you in the city (NYC). Safe travel
Generator won't start! Lily&Me Generators & Solar Power 14 09-11-2012 05:23 AM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
