Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-22-2016, 09:55 AM   #21
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
Why the 9280 rather than the 9260, or 9270? If 55 amps charging capacity was good enough from the factory, what are the benefits of going to 80A? Would the larger size require up sizing any of the wires/cables?
Are these models compatible with the factory solar system and gel cell batteries that I hear prefer slightly different charging voltages than the lead-acid batteries that are used without the solar system?
Given that our less than one year old factory Convertor/Charger just failed on our most recent trip with our 2016 Classic with 50A service and factory 100W solar system, and our warranty replacement visit to the Airstream Factory Service Center is about a month off, I am wondering if we should use this opportunity to upgrade to a multi-state charger instead.
I am hoping for a simple do-it-yourself replacement if possible for someone who is reasonably handy. Do these fit that desire?
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
Old 06-22-2016, 03:10 PM   #22
Seattle , USA
Yes, these are all compatible with AGM/gel cell batteries and the factory solar system.
The advantage of the 80 amp 9280 is that it will charge depleted batteries much faster. Yes, you should have adequate 12v and ground cable for this instance, but in my trailer the factory wiring was more than sufficient. Remember, the full 80 amps of current will NOT be drawn under normal circumstances until it is NEEDED; i.e., recharging massively depleted batteries or a very large 12v load. It is probably overkill, but I've never even had the fan come on in either of my trailers, both of which have the 80 amp units. However, the 80 amp unit is not usually a direct simple swap out; some of the other models are very simple plug/play/direct fit replacements that are much, much more simple to install. I simply chose overkill over ease of installation-but that is your choice to make. You can't really go wrong with any of the Intellipower units. The factory unit is a true piece of embarrassing unworthy bison scat.
RareStream is offline   Reply With Quote
Old 06-23-2016, 07:09 PM   #23
1962 22' Safari
2016 30' Classic
Images: 41
Thanks RareStream,
I've been doing a lot of reading since my last post. It seems that Progressive Dynamics, PowerMax (Boondocker), Iota, and Xantrex all have their plus's and minus's when comparing dimensions, modes, voltage levels, etc. None seem a perfect match for the info I found about charging Lifeline batteries on their web site. I might take some time to make a decision.
Joe
Old 06-23-2016, 10:35 PM   #24
Naples , Florida
Originally Posted by 66Overlander View Post
Thanks RareStream,
These are all compromise chargers and NONE of them have temperature compensation to regulate the level of charging voltage.
The best alternative is to use a Magnum MMS-1012 for the fully programmable charging section along with their temperature sensor or go to the new Victron Centaur charging system and their BMS-700 battery monitor system.
Either will be light years ahead of any converter available.
lewster
Old 06-25-2016, 08:59 PM   #25
1962 22' Safari
2016 30' Classic
Images: 41
I understand, but some of us don't need an ultimate boondocking package. But, if I upgrade the charger, I might just move it to under the front couch near the batteries, as it was for decades until recent years. That would solve the issue of voltage drop in the long 6awg positive and negative cables from the mid trailer charger to the tongue mounted batteries and it would make adding a battery temp sensor easier.
I am hearing that Airstream moved the charger to this position on the 2017 Classics, finally correcting one of their previous design mistakes.
In any case, I think the short term answer is just to have the original charger repaired or replaced under warranty and then take my time determining the best long term solution.
Joe
Old 06-25-2016, 11:01 PM   #26
1979 28' Ambassador
2014 27' FB Classic
Port Townsend , Washington
I am there with you Joe. Magnum is nice but I just can't justify dropping $1000 - $2000+ for a converter. I do wish Airstream would have left the charger up front by the batteries instead of putting it mid-cabin. They put the inverter up front on my 2014 Classic but the converter is mid-cabin...makes no sense.
My plan is to put in a Progressive Dynamics PD4655 as a direct replacement for my Parallax 7355. I leave my unit plugged in most of the time so I want a multi-stage charging unit that won't cook my batteries. Just put in a pair of new Group 27 Interstate batteries and would like them to last more than 2 years.
rdepas is offline   Reply With Quote
Old 06-26-2016, 12:02 AM   #27
Naples , Florida
Originally Posted by Bob Little View Post
Forgive my ignorance of what I just recently purchased...a 2016 Flying Cloud 19'...but I would like the long term assurance of a stable battery current supply. Can anyone tell me whether I have the 'bad' inverter/charger and where it might be located in my front dinette/rear bedroom model? Would it be reasonably easy for a non-EE degree-holder to replace?
Many thanks in advance for the 'informational energy supply' provided 24 hours a day by the Air Forum! .
Bob,
I owned a 19 International CCD for 6 years. You don't have a lot of usable space for upgrades, but there is room under the dinette where your water tank is located and also in front of the storage drawer on the curb side.
In fact, I have an installation starting Monday for a 200 amp/hour Victron lithium battery bank, Victron 2000VA hybrid sine wave inverter/charger and 200-300 watts of solar with Victron solar charge controller and monitoring systems. It will be a squeeze but everything will fit nicely!
Your unit has the dreaded Parallax single voltage converter (AKA battery burner) and the WFCO 1000 watt inverter. If you are serious about upgrading your electrical capacities with an eye on boondocking, there are many ways to achieve this.
Some folks seem to get extended battery life from the OEM Airstream converters, but I have a regular stack of dead Interstate batteries from new or fairly new trailers that prove otherwise. In addition, anyone with any training in how batteries should be charged will tell you that a continual voltage of 13.6VDC will neither fully charge your batteries nor will it allow them to float once full (if they ever reach that state).
Most liquid cell batteries require a bulk/absorb charge level of up to 14.8VDC and a float charge of 13.2-13.4VDC. AGM batteries are lower at 14.2-14.4VDC for bulk/absorb and float of 13.2VDC. These numbers are direct from the manufacturers' specifications and charging requirements.
This results from a Parallax single voltage charger are either chronic under or overcharging and is the primary reason for the death of the Interstate batteries (coupled with the simple fact that they are near junk status even when new!).
What you put into your 19 depends entirely on how you intend to use it.
lewster
Old 06-26-2016, 12:12 AM   #28
Seattle , USA
Bob,
Here is a picture of a Progressive Dynamics 9280 mounted in the factory location on a 19ft Bambi:
Old 06-26-2016, 12:39 AM   #29
1962 22' Safari
2016 30' Classic
Images: 41
We cannot leave our trailer plugged in full time where we currently store it and we do not often even camp in the same location for more than a week before moving (while using various 12V system in the Airstream), so my main concern at this time is opposite yours. It is under charging of the expensive Lifeline AGM batteries when we use it and thus not getting full use and life from them, rather than overcharging during periods of non use.
It is more about getting the right higher than stock 13.6V voltage during the Bulk and Absorbsion stages of the charging cycle than it is reducing the voltage below 13.6V during the Float stage.
Ideally, it would be good to get the proper voltages in all parts of the charging cycle, though, in case our storage opportunity or usage pattern changes in the future.
Joe
Old 06-26-2016, 08:35 AM   #30
1962 22' Safari
2016 30' Classic
Images: 41
Originally Posted by Clozzzer View Post
Also, I believe the 4655 is for 30 amp service and not 50 like I have. I have 2 ac's.
After investigating this question, I believe the PD4655 would work "electrically" to replace the converter section of the Parallax 5355 converter in 50 Amp/dual AC Airstreams, but the problem is physical packaging space.
While the PD4655 is a direct bolt in replacement for the converter section of the Parallax 7355 used on 30A/single AC Airstreams, it is taller than the converter section on the 5355 in recent 50A/dual AC Airstreams. To use it would require some type of modification on 50A Airstreams. All three of the 5355, 7355, and 4655 have 55A charging capability.
It appears to me that based upon physical dimensions, the 60A PD9260 (or same size 70A PD9270), or any of the 55A PowerMax Boondocker series could be retrofitted inside the existing 5355 Converter section case (after removing the "guts" of the 5355 converter) and thus be bolted back into place. Several on AirForums have done this modification at least with the 55A PowerMax Boondocker.
The 55A Iota DLS-55/IQ4 looks like it would also fit inside the 5355 converter case, but not sure if anyone has done so here on AirForums. The Xantrex TrueCharge 2 60A is OK on height and depth, but is too long (wide) to fit inside the 5355 converter case, but might fit if one cut one end off the 5355 converter case or it might fit below the 5355 circuit breaker panel if the 5355 converter case was removed entirely and a new way to mount the 5355 12V fuse panel was created. At least one person on AirForums has done this type of Xantrex below the circuit breaker panel replacement, but I believe on a 30A/single AC, 7355 equipped Airstream.
Search around and you will several that have posted photos of their converter replacements here on Airforums (sorry, I don't have the links handy to post).
Beyond the physical dimensions, you will find that the charging voltages in various modes and other features of all the models I listed vary quite a bit. They each have their plus's and minus's and none are "perfect". Given the long run of wire from the mid trailer mounted converter to the front mounted batteries (meaning higher than recommended resistance, thus decreased charging ability), having a higher charging voltage than the stock 5355 (13.6V) during the Bulk and Absorbsion charging stages (especially if you have the expensive Lifeline AGM Batteries that come with the factory solar package) might be as important as having a reduced voltage (i.e. below the stock 5355 13.6V) during the Float stage to reduce overcharging during long periods where the trailer is plugged in but not used (especially for the lead-acid Interstate batteries used without the solar package). It might be worth your time to study those details before just going with the first 3 or 4 stage charger you find that physically fits.
And all of this is before one might consider going to a Magnum Inverter/Charger that offers more features and customization, but at significant additional expense. For some the Magnum might be an option, but for some of us it is likely overkill.
There are other Converter/Chargers out there (including some brands directed specifically toward the marine market - and thus likely more expensive), but I did not investigate, as I have heard no one here endorse them other than the brands I specifically mention in this post.
I am finding that this upgrade will take me additional time to investigate before making a decision. I am even considering moving the charger from under the circuit breaker panel to under the front couch to reduce the voltage drop in the long wires and thus improve charging of our Lifeline batteries. Not sure yet if I will decide if this is necessary, but I will note that the converter was located under the couch near the front mount batteries for decades (it was there in our previous 1985 and 1994 Airstreams) before the relatively recent Airstream decision to move the converter to a mid trailer location. I have heard that at least for the Classic, the converter is moving back below the front couch for 2017. Not sure of converter location on the other 2017 Airstream models.
Joe
Old 06-27-2016, 09:39 AM   #31
2020 Classic 33
Box Elder , South Dakota
Maybe give a call to Progressive Dynamics and ask them which model to use?
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 07-15-2016, 11:11 PM   #32
2016 30' Classic
Rocklin , California
I plead ignorance here but I am having trouble wrapping my head around the idea that I just spent a boat load of cash for a 2016 Classic only to be told that the electrical components installed by the manufacturer are substandard and need to be upgraded because they will cook my batteries and fail anyway. Why in the world on trailer as expensive as these would they not make an effort to do it right the first time and put in the best components available? I know I would have spent more to have it right in the first place. I find this concept distressing.
Gamehawkers is offline   Reply With Quote
Old 07-15-2016, 11:36 PM   #33
Ag&Au's Avatar
Port Orchard , Washington
It is not necessary to spend more to have it right. It could be possible for the manufacturer to start developing a culture of their workers taking pride in their work, and at the same time, taking a cut in their own profit, to make a product they could really be proud of rather than living off of a reputation made years ago when Airstream was truly a quality brand. Don't think Airstream is alone. This is a trend in a lot of american manufacturing.
Ken
Old 07-15-2016, 11:53 PM   #34
Naples , Florida
If you're ;looking for what is probably the BEST battery charger presently available, look to the Victron Phoenix: https://www.victronenergy.com/upload...Charger-EN.pdf
Fully programmable 4-stage charging: Bulk, Absorb, Float and Storage with a weekly increase from storage voltage back to absorb for an hour to 'top off' your batteries and keep them at 100% with full temperature compensation. These are features that you will not find available in ANY converter sold today.
For those that don't want the inverter side of a Magnum inverter/charger, this Victron device is a charger ONLY!
lewster
Old 08-26-2016, 02:04 PM   #35
DarrellT's Avatar
Longview , Texas
Our 2017 26U is due in next week. Asked the dealer if they'd replace the converter/charger to a 3-stage before we pick it up. No-can-do, that voids the warranty on all the 12V system if we do! So knowing we are going to leave our coach on 24/7 shore power, they'd rather replace the batteries and/or charger possibly numerous times rather than install the right charger up front
DarrellT is offline   Reply With Quote
Old 08-27-2016, 03:20 AM   #36
2000 30' Excella
2014 30' Classic
Princeton , Iowa
We have a '16 26 U and we leave it plugged in to shore power 24/7 and have had no problems with converter, I cannot find anything in info. that says you will. Love the trailer.
larryglarson is offline   Reply With Quote
Old 08-27-2016, 04:37 AM   #37
Goliad , Texas
There are converters that incorporate a 4th charge state now for "storage". If the converter does not see a draw on the batteries they will go into lower voltage state to keep from boiling the water out. I believe Magnum has this in their newer converters and others as well.
Just get on the net and do some searching and you will find several with this 4th state.
eartick is offline   Reply With Quote
Old 08-27-2016, 04:40 AM   #38
Goliad , Texas
What Lewster says. 4th state charging. Will not boil your water off while in storage. Great stuff.
Old 08-27-2016, 05:38 PM   #39
Woody48's Avatar
2016 28' Flying Cloud
Oakdale , Pennsylvania
Parallax TempAssure upgrade
As a new owner I had my problems with the original batteries dying a week after I picked up my trailer in April. Interstate replaced the batteries and I have been reading everything I can get my hands on since then. Short of replacing the lower charging section of my converter (Parallax 5355 for my 50amp service 2016 27'FC), I see that Parallax offers a TempAssure bolt on upgrade(http://www.parallaxpower.com/4400tau...pgrade-4400tau). According to Parallax this module boosts the the charging voltage 0.5v and adjusts the voltage according to battery temperature. From what I can read this would seem to solve part of the issue of cooking your batteries while constantly being pluged into shore power especially during hot weather. My question is:
1) Is this upgrade to the Parallax worthwhile (cost ~$50).
2) How do I run the cable from the TempAssure module which plugs into the front of the converter back to the battery to sense the battery temperature.
Thanks in advance for any input.
Woody48 is offline   Reply With Quote
Old 08-28-2016, 02:36 PM   #40
Seattle , USA
Parallax SUCKS.
Either take the advice of those of us who have BEEN DOWN THIS ROAD or destroy your batteries.
Stop pussyfooting around the issue and put in a GOOD converter and BE DONE WITH IT.
Sheesh.
2016 International 27FB - 50amp service Q's KariRich Electrical - Systems, Generators, Batteries & Solar 5 04-07-2016 04:39 PM
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 09:51 AM
50amp for 30amp trailer? racoco Electrical - Systems, Generators, Batteries & Solar 15 08-24-2007 07:43 PM
Power Inlet 50amp markdoane Electrical - Systems, Generators, Batteries & Solar 4 10-14-2005 08:25 PM
30amp to 50amp? alfalsetto Airstream Motorhome Forums 17 08-16-2003 06:42 AM
