Old 08-02-2011, 06:05 PM   #1
streamliner
Westwold , British Columbia
What kind of plug terminal is this?
After taking a cursory glance at the power supply plug on my 1964 Streamline I assumed that it was a standard NEMA tt-30 style plug and so I went to the hardware store and bought an adapter.
When I got home I quickly discovered that my trailer had a slightly different style of plug (see picture). What exactly have I got here?
bookem666 is offline   Reply With Quote
Old 08-02-2011, 06:12 PM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Looks like a 50amp service plug.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 08-02-2011, 06:38 PM   #3
streamliner
Thanks. That helped me figure it to be NEMA 10-50.
No luck so far in finding an adapter.
Old 08-02-2011, 08:14 PM   #4
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
You won't fond an adapter-that will only plug into a 50amp service outlet. Ck and see if your trailer is set up for 50amps. One of the breakers in the breaker box should be 50amp if it is.
Bruce
Need a 35 Amp Bargman 110v Plug!! 1958 745classic Batteries, Univolts, Converters & Inverters 12 09-17-2017 01:38 PM
New 30 amp plug needed ck21084 Batteries, Univolts, Converters & Inverters 21 09-29-2016 11:42 AM
Wanted - 35 Amp Bargman 110 VAC Plug mbrod666 Electrical - Systems, Generators, Batteries & Solar 2 07-15-2011 12:31 PM
30 amp plug into 50 amp welder outlet? hipsters Electrical - Systems, Generators, Batteries & Solar 17 07-06-2011 03:56 PM
Wet weekend in our Safari OR How I discovered the Blow Out Plug! Brow324 Plumbing - Systems & Fixtures 16 04-18-2011 11:15 AM
