Old 07-29-2014, 10:05 AM   #1
1968 26' Overlander
Wolfforth , Texas
What is this wire for?
A large blue wire running from box to front of trailer but it was cut off in front.Click image for larger version
Name:	ImageUploadedByAirstream Forums1406649932.571568.jpg
lakoria is offline   Reply With Quote
Old 07-29-2014, 10:12 AM   #2
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
The only blue I'm aware of is the charge line that goes from the tow vehicle to the battery.
Cyquest is offline   Reply With Quote
Old 07-29-2014, 10:19 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Well, in the movies, when there's a red wire and a blue wire, you cut one of them to keep it from going "Boom." Since your trailer didn't go "Boom" they must have cut the correct wire!
Sorry, when I saw the picture I couldn't resist…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-29-2014, 01:28 PM   #4
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
On my '62, if I remember correctly, the blue wire went to the trailer brakes.
Thalweg is offline   Reply With Quote
Old 07-29-2014, 01:39 PM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Pretty sure it's the green wire.... no wait the yellow?
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 07-29-2014, 05:56 PM   #6
68Streamline's Avatar
Cerritos , California
Name:	ImageUploadedByAirstream Forums1406678164.341916.jpg
The attached diagram shows where the blue wire goes to the electric brakes.
68Streamline is offline   Reply With Quote
Old 07-30-2014, 11:45 AM   #7
1968 26' Overlander
Wolfforth , Texas
Thanks, so it's either the brakes or the charge?
The more I work on things the more mysteries I find!
Old 07-30-2014, 12:22 PM   #8
Central , Mississippi
On my '63, EVERY ONE of the 12V wires were blue and all tied together as a single circuit.
The brakes were yellow and black. All of the wires for exterior lights were black.
Standards? not so much back then.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-30-2014, 12:28 PM   #9
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Typically, in the umbilical cord, blue is for the brakes. Black is the charge, and white is the common/return/ground. However, in 1968, Airstream did not follow the current standard used for umbilical wiring. And if a PO re-wired things, pretty much anything goes.
Got a volt meter or test light? See if the blue wire has +12 VDC on it. If it doesn't, it may be for the brakes, but the only way to know for sure is to physically trace it and see where it goes.
Do you have a blue wire that connects to the brakes under the trailer? The current standard is to have a blue and white wire connecting to the brake wires. The brake wires themselves (coming out of the backing plate) may be blue and white or red and white. If you have a blue wire from the trailer connected to the brakes, to test to see if the blue wire at the tongue is connected to it, disconnect the blue wire from the brakes and check for zero ohms with an ohm meter between the two ends of the blue wire. If you have zero ohms, it's the same wire. Don't forget to re-connect the brakes after making the test.
Chris
Old 07-30-2014, 02:18 PM   #10
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
On our '66 Safari, that blue wire is the charge line.
Old 07-31-2014, 03:30 PM   #11
1968 26' Overlander
Wolfforth , Texas
Thanks so much for info, I'll do done testing when I get back. We're hiking Grand Canyon!
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 08:18 PM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 08:25 PM
