Old 01-31-2009, 07:42 PM   #1
Frieberg's Avatar
1975 Argosy 24
Vail , Arizona
What is this strange light on the side of my trailer?
There is a strange 1/2 inch crystal ball looking light on the outside of my 75 argosy 24". It is above the battery compartment and has wiring going to though an outlet box on the inside. I always wondered what it was and never knew it was a light till tonight. It was only on for a little bit and I dont think I could get it on again if I tried, but heres what I did. I plugged the trailer into power from my shop. At first everything ran like normal (lights were brighter than just 12V) but then things went just a little dimmer (not 12V dimmer though) and that strange light came on. Somebody must know what that light is...... maybe a "short" indicator light? thanks, Mark
Frieberg is offline   Reply With Quote
Old 01-31-2009, 07:49 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
That light is a "reversed polarity" light and tells you that the outlet you're plugged in to has the neutral and hot lines reversed. It should have come on instantly. Check it again.
The light itself is dangerous. If you have two faults--first the reversed polarity and second a bad ground--you're shell will be hot (through the filament of the light) with respect to earth, but no breakers will blow. If you are standing on damp earth and touch the shell, you will get a shock. Many posts recommend removing the light.
Zep
Old 01-31-2009, 07:51 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It is a reverse polarity light. The hot and neutral leads are switched at the outlet or your power cable is messed up. The light being on is bad.
Richard
Old 01-31-2009, 07:57 PM   #4
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Purchase one of the cheap polarity checkers, take a marker and color it to match your interior and leave it plugged in all the time. I painted mine silver and is plugged into the outlet by my stove, I check it every time I hookup and it stays on 24/7.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 01-31-2009, 08:01 PM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
I have one of those and an AC volt meter plugged in the outlet opposite the door. It's the first thing you see when you open the door.
Richard
Old 01-31-2009, 08:07 PM   #6
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Originally Posted by Zeppelinium View Post
Zep
Congrats in advance for your 2000th post!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 01-31-2009, 08:18 PM   #7
Jim Clark's Avatar
I will have to track down a meter. Thanks
Jim N5TJZ Air# 174
2011 F150 Ecoboost
trailer side brake wiring diagram? munimula Brakes & Brake Controllers 9 03-26-2017 09:53 AM
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Trailer heavy on one side! Chopper Axles 33 09-27-2006 09:21 AM
30 amp cord connection in trailer side davidz71 Electrical - Systems, Generators, Batteries & Solar 25 01-31-2006 10:10 AM
Light on side of coach overlander63 All Argosy Trailers 9 07-02-2003 08:32 PM
