Old 10-23-2007, 07:11 PM   #1
1979 Argosy Minuet 6.7 Metre
Ridgeville , South Carolina
What is this?
My Argosy has a little light looking thing on the left rear corner. It is about as big around as a nickel. It is plastic and pertrudes about 1/4 inch. It doesn't light up, but I'm not sure if its supposed to. It is finished to look like a cheap toddler's jewel. Does anyone know what it is? Thanks.
buzzbuck is offline   Reply With Quote
Old 10-23-2007, 07:18 PM   #2
ibgl6's Avatar
Southport (Panama City) , Florida
Send a message via AIM to ibgl6
I believe it is a warning light of sorts to indicate reversed poliarty when plugged into shore power?.....SAM
Your Friend Sam In (Southport) Panama City Florida
Air#15607 TAC FL-2
Good Sam (LifeTime Member)
ibgl6 is offline   Reply With Quote
Old 10-23-2007, 07:18 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
It sounds like a little automotive indicator light that a prior owner installed possibly to show on the outside that something was left on. What color is the jewel part? Have you tried easy the thing out? If it's the kind of light that I'm thinking of, it should pop out. Post a photo of if you can.
Brian
SuEllyn & Brian McCabe
Old 10-23-2007, 07:25 PM   #4
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
What is this
That is the reverse polarity indicator that all Argosy's have just too the right of the battery box.
Gunny
Gunnyusmc is offline   Reply With Quote
Old 10-23-2007, 07:45 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
It would indicate that the outlet you plug into is incorrectly wired. That's why it is at that corner of your Argosy. If the hot wire is reversed it would mean your Argosy shell and frame are HOT and touching could electrocute you. I've not seen that but campgrounds sometimes are DIY affairs...
5 meter Langford Nahanni
Old 10-23-2007, 08:46 PM   #6
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
indeed
It is indeed a reverse polarity indicator. Ours is located in that exact same location. It is NOT next to the battery box. Not lit is correct and good. Prying it out is probably a bad idea. It can be accessed from a work box inside the rear cover on our Minuet.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
