Old 04-11-2013, 06:39 PM   #1
eugene , Oregon
What is this?
I am the new owner of a 2006 23' safari se.
There are some wiring components that are located next to the front wall that I can't identify their function/purpose.
These are now under a remodeled dinette. It originally had a gaucho sofa in the space.
please See attached pictures.
cyafishin is offline   Reply With Quote
Old 04-11-2013, 07:08 PM   #2
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Might want to get better pictures and start tracing wires. I think the object on the left might be an batter isolation solenoid, they do come in different shapes, sizes, and configurations and rating. A typical example is below. As far as the other box start following the wires and see where they lead you. See if you can find a name on either item. Black box could be a voltage regulator to a trickle charger to a CIA tracking device.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 04-11-2013, 08:33 PM   #3
dznf0g's Avatar
Oswego , Illinois
I believe the black box is simply a positive junction block. I think you'll find your umbilical wires terminated there as well as a 12V supply for some other circuits which do not run through the fuse panel originating there. Like the orange wire with the in line fuse holder.....I believe goes to your propane detector.
-Rich-
Old 04-11-2013, 08:36 PM   #4
Jim Clark's Avatar
That is good to know, now I know where to check for those pesky items that drain your battery when it is isolated.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 04-11-2013, 10:52 PM   #5
eugene , Oregon
Another pic
This is another pic of the mystery electronic equipment.
Old 04-12-2013, 01:15 AM   #6
2005 19' Safari
GLENDALE , AZ
I think that's the solenoid you hear clicking when you push the "storage" switch near the front door. If it is, it disconnects most of the 12-volt circuits when your Airstream is in storage. However, the other wires on the busbar in the photo in your first post probably go to the "phantom drains" that everyone talks about, that cause batteries to go dead after a few weeks in storage.
Is there a specific reason for your original question, or were you just curious?
Old 04-12-2013, 11:32 AM   #7
eugene , Oregon
I am in the process of evaluating my systems. My batteries are dead.
They were old when I bought the trailer, and i think i killed them by keeping my trailer plugged in over the winter in storage. I'm contemplating whether to replace my converter.
in the process I was simply looking around at the wiring and couldn't ID the purpose of these devices.
